OUTPUT DO1
The DO1 output physically shows a high state. After uploading new software, when logging in directly to the controller, the inputs and outputs are disabled, but DO1 physically remains on all the time. I have no idea what is causing this. I haven’t connected any relays to the outputs yet.
can you take a photo or video of your problem.
ALL INPUT - OFF
ALL OUTPUT - OFF
Nevertheless, the output physically outputs a constant voltage of 12VDC.
take a photo of your AIO board, i want to see how you wire cable.
Pin 1 -- VIN 12 V DC
Pin 3 -- wyjście 2
Pin 2 - wyjście 1 (światło)
if you disconnect the output1 wire, the OUTPUT1 LED also is ON?
(12-29-2025, 06:46 PM)administrator Wrote: jeśli odłączysz przewód wyjściowy 1, to dioda LED OUTPUT1 również będzie włączona?
Yes
The remaining outputs that are defined in the HA code work properly.
can you resolder the pcb, maybe need replace the output1's mosfet.
MOSFETs may be subject to electrostatic breakdown.
I think I have a friend who can handle this soldering for me. Could you give me the circuit board diagram and tell me which component might need to be replaced and its symbol?
