LAN8720 DHCP implementaion with mqtt arduino source code
Hi.
I bought KC868-A2 board.
I am tryning to send mqtt message to the mqtt broker through LAN8720 with dhcp configuration.
Any example arduino code on this.
Many Thanks for this wonderfull board. Nice Work!!!
you can download KCS v2 firmware, enable MQTT, then you can directly to use it.
if you want write your own arduino code, here is LAN8720A arduino demo code: https://www.kincony.com/forum/showthread.php?tid=2638
you can add some mqtt code based on it.
