3 hours ago
Hi,
the activity LED in the RJ45 jack of my B16M seem to be inverted: the link LED is on while no cable is connected and goes off once the link is up. The activity LED seems to be fine (is on when there is traffic). Ethernet itself works fine (W5500, DHCP).
According to the W5500 datasheet (v1.1.0, pins 24-27), the LED outputs are active low, e.g. LINKLED "Low: Link is established", and no register changes that. So I assume the jack LED is connected between the W5500 pin and GND instead of between 3.3 V and the pin.
Can you check this in the schematic, and is it fixed in a newer board revision? My boad reads "V1.3". The G1 seems to have a similar issue: https://www.kincony.com/forum/showthread.php?tid=9552
Best,
Bernhard
Best,
Bernhard
