Getting Started with ESPHome and Home Assistant
Threads
- Esphome + KC868-HA-V21 (8 Replies)
- Instal ESP HA with ethernet (3 Replies)
- AS-ESP32-S3 won't initialize (10 Replies)
- Device change after damage (1 Reply)
- TA with Home Assistant with Ethernet Only (3 Replies)
- Kincony KC868-A4 flashen not work (5 Replies)
- Operating WLAN and Ethernet together (2 Replies)
- Need help choosing modules for 32-channel lighting control with Home Assistant (6 Replies)
- B16M Outputs & HomeAssistant Firmware (1 Reply)
- Water supply automation (1 Reply)
- how to use binary sensor make VOICE CALL by SIM7600E 4G module in ESPHome (9 Replies)
- Error: Installing ESPHome on Windows without Home Assistant/Rasberry Pi (1 Reply)
- Retain Switch status ESPHome after reboot and update / Ethernet setup (5 Replies)
- Need Help Getting Started with ESPHome and Home Assistant Integration (8 Replies)
- how to turn on relay by SIM7600E 4G module voice call in ESPHome (12 Replies)
- ESPHome PCF8575 and XL9535 yaml format define updated (0 Replies)
- how to use binary sensor send SMS by SIM7600E 4G module in ESPHome (0 Replies)
- 868-A4S (9 Replies)
- how to slove ESP32 DAC dimmer output voltage is not linear issue (0 Replies)
- Need Help Getting Started with ESPHome and Home Assistant Integration (1 Reply)
- KC868-H32B Pro with Home Assistant (4 Replies)
- how to connect KC868 to home assistant (8 Replies)
- 2021 Apple TV IR Codes (0 Replies)
- how to config ESPHome support Tuya module for KinCony ESP32 board (0 Replies)
- how to install esphome on home assistant for beginner (2 Replies)
- Updating ESPHome By Windows OS Command Line (0 Replies)
- how to use ESPHome dashboard in Windows OS (0 Replies)
- ESPHOME 2023.12.0b2 breaking change (7 Replies)
- Communicate between multiple ESP's with RS485 Modbus (10 Replies)
- door sensor convert to RS485 in ESPHome using KinCony HAv2 module (0 Replies)
- how to use Tuya app remote control ESP32 relay board by internet in ESPHome (17 Replies)
- publish sensor initial state at boot on home assistant after power failure (2 Replies)
- how to use ESPHome on Windows PC without home assistant & raspberry pi (0 Replies)
- how to integrate ESP32 relay board to Loxone Miniserver by ESPHome (0 Replies)
- KinCony ESPHome-Tuya-iot component (0 Replies)
- how to use analog output 0-10V DAC by esphome for home assistant (0 Replies)
- how to use 4-20mA / 0-5v analog sensor by esphome for home assistant (0 Replies)
- how to use switch button by esphome for home assistant (0 Replies)
- how to use gpio binary sensor by esphome for home assistant (0 Replies)
- how to use gpio relay switch by esphome for home assistant (0 Replies)
- how to enable the USB ports on Raspberry Pi CM4 (0 Replies)
- how to install home assistant on raspberry pi by easiest way (0 Replies)
