05-06-2024, 06:34 PM
Hello, I have two Kincony A16 boards. Im using toggle buttons, but after some time output automatically turns off, and this happens with both Kincony boards with every output, wiring is good, what can be the reason? This how the code looks like:
friendly_name: Kincony2
type: arduino
sda: 4
scl: 5
encryption:
key: "pbLoAOpRUI49e65b0pCUrVShaclU3bM38vlGfnNQ9YY="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Af6E50"
password: "ajhfwy1kFdbc"
captive_portal:
- id: 'pcf8574_output1' # for output channel 1-8
address: 0x24
- id: 'pcf8574_output2' # for output channel 9-16
address: 0x25
- id: 'pcf8574_input1' # for input channel 1-8
address: 0x22
- id: 'pcf8574_input2' # for input channel 9-16
address: 0x21
friendly_name: Kincony1
type: arduino
sda: 4
scl: 5
encryption:
key: "tBC8hXDhMHsgklwFmZerS9tVQP0p+6Qus3+OyUTj+Jo="
ota:
wifi:
ap:
ssid: "Esphome-Web-B050E4"
password: "SziFua377JQb"
captive_portal:
address: 0x24
address: 0x25
address: 0x22
address: 0x21
# Outputs
name: "Living room "
pcf8574: pcf8574_output2
number: 7
mode: OUTPUT
# Inputs
name: "Living room switch"
pcf8574: pcf8574_input1
on_press:
then:
- switch.toggle: livingroom
type: arduino
sda: 4
scl: 5
encryption:
ota:
wifi:
ap:
captive_portal:
address: 0x24
address: 0x25
address: 0x22
address: 0x21
type: arduino
sda: 4
scl: 5
encryption:
ota:
wifi:
ap:
captive_portal:
address: 0x24
address: 0x25
address: 0x22
address: 0x21
# Outputs
number: 7
mode: OUTPUT
# Inputs
on_press:
then:
