06-24-2026, 11:10 AM
Hi Kincony,
I have bought some of your B4M modules, and try to use the RS485 port.
I try to run the code here: https://www.kincony.com/forum/showthread.php?tid=8934
but cannot receive the data from RS485 port. The log shows that port is not available.
Can you help me troubleshoot this issue?
Best regards,
Hai Pham
* RS485 Communication Test
* The TXD pin is defined as GPIO 18 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 39
#define RS485_TXD 38
while (!Serial);
// Send a test message
rs485Serial.println("Hello from KinCony B8M!");
// Wait for a short period
delay(1000);
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
} else
Serial.println("RS485 is not available");
delay(2000);
}but cannot receive the data from RS485 port. The log shows that port is not available.
Best regards,
Hai Pham
