B16 ESPHome yaml for home assistant with tuya
Sir, I'm enjoying my B16. Thank you for giving us the opportunity to play with smart home by your consistent innovations. I even more appreciate your sharing of knowledge. Thank you!
I'd like to just say this for this warning keeps coming up. We are still getting this messages every time we compile our YAML file. It is not an error, but just a warning. I thought you might like to update it.
WARNING Using `switch.SWITCH_SCHEMA` is deprecated and will be removed in ESPHome 2025.11.0. Please use `switch.switch_schema(...)` instead. If you are seeing this, report an issue to the external_component author and ask them to update it. https://developers.esphome.io/blog/2025/...recations/. Component using this schema: tuya_wifi_mcu
Again, I enjoy your products very much. You at Kincony are so innovative, hardworking and generous to share knowledge. And you always answer very quickly.
Thank you. Have a good day!
RE: B16 ESPHome yaml for home assistant with tuya - by ck1 - 07-15-2025, 12:20 AM
