Custom ESPHome firmware and Tuya integration
#31
that need to use tuya license.
(10-13-2025, 10:18 AM)admin Wrote: that need to use tuya license.
I have license for KC868-A6
I use example in  GitHub - hzkincony/esphome-tuya-iot
change   ref: v1.2.0 to  ref: v1.2.1
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-tuya-iot
      ref: v1.2.1
and get error in
src/esphome/components/tuya_iot/tuya_iot_component.cpp: In member function 'virtual void esphome::tuya_iot::TuyaIotComponent::update()':
src/esphome/components/tuya_iot/tuya_iot_component.cpp:292:19: error: 'esp_mqtt_client_config_t' {aka 'struct esp_mqtt_client_config_t'} has no member named 'username'
292 | mqtt_cfg_.username = username;
my mqtt correct
mqtt:
  broker: !secret mqtt_host
  username: !secret mqtt_username
  password: !secret mqtt_password
есть какие-то идеи, как исправить ошибку?
post your yaml file at here.
(02-20-2026, 02:10 AM)admin Wrote: post your yaml file at here.
# Basic Config
  friendly_name: KC868_A6_Test
#  platform: ESP32
#  board: esp32dev
  - source:
      type: git
      ref: v1.2.1
#    type: esp-idf
#    type: arduino
    type: arduino  # Важно изменить на arduino
    version: latest
  encryption:
    key: "mdhQnkxHuyHBBOp3c+vVZw1mijHvK6GlGVDXbwhzSMM="
mqtt:
ota:
  - platform: esphome
#    password: "5992f85d33c321fdc84443dbf6d1eab2"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kc868-A6-Test Fallback Hotspot"
    password: "iuUkzi7OQNef"
captive_portal:
time:
  - platform: homeassistant
  sda: 4
  scl: 15
    address: 0x24
    address: 0x22
# Individual outputs
    on_turn_on:
      - lambda: !lambda |-
          id(tuya_iot_component).property_report("output1", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output1", false);
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
    on_turn_on:
          id(tuya_iot_component).property_report("output2", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output2", false);
      mode: OUTPUT
    on_turn_on:
          id(tuya_iot_component).property_report("output3", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output3", false);
      mode: OUTPUT
    on_turn_on:
          id(tuya_iot_component).property_report("output4", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output4", false);
      mode: OUTPUT
    on_turn_on:
          id(tuya_iot_component).property_report("output5", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output5", false);
      number: 4
      mode: OUTPUT
    on_turn_on:
          id(tuya_iot_component).property_report("output6", true);
    on_turn_off:
          id(tuya_iot_component).property_report("output6", false);
      number: 5
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
#switch:
#  - platform: gpio
#    pin: 25
#    name: "switch test 1"
#    id: switch_test_1
#    on_turn_on:
#      - lambda: !lambda |-
#          id(tuya_iot_component).property_report("output1", true);
#    on_turn_off:
#          id(tuya_iot_component).property_report("output1", false);
#  - platform: gpio
#    pin: 26
#    name: "switch test 2"
#    id: switch_test_2
#    on_turn_on:
#          id(tuya_iot_component).property_report("output2", true);
#    on_turn_off:
#          id(tuya_iot_component).property_report("output2", false);
tuya_iot:
  product_id: xp***lm
  device_id: 26***3j
  device_secret: H***w
  region: eu # eu, us, eus, weu, in, cn
  # eu: Central Europe Data Center
  # us: US West Data Center
  # eus: US East Data Center
  # weu: Western Europe Data Center
  # in: India Data Center
  # cn: Chinese Data Center
  on_event:
    - event_name: property/set
      then:
              // Append the required switch in switch_map to respond to commands issued by Tuya.
              static std::map<float, switch_::Switch*> switch_map {
                { 1, id(light1) },
                { 2, id(light2) },
                { 3, id(light3) },
                { 4, id(light4) },
                { 5, id(light5) },
                { 6, id(light6) },
              bool is_target_output = false;
              bool output_state = false;
              int output_number = 0;
              // Modify this number 2 to match the number of switches in the above switch_map.
              for (int i = 1; i <= 6; i++) {
                String key = "output" + String(i);
                if (x.containsKey("data") && x["data"].containsKey(key.c_str())) {
                  is_target_output = true;
                  output_state = x["data"][key.c_str()];
                  output_number = i;
                  break;
              if (is_target_output) {
                auto iterator = switch_map.find(output_number);
                if (iterator != switch_map.end()) {
                  auto sw = iterator->second;
                  if (output_state) {
                    sw->turn_on();
                  } else {
                    sw->turn_off();
              bool is_target_all_on = false;
              bool all_on_state = false;
              if (x.containsKey("data") && x["data"].containsKey("all_on")) {
                is_target_all_on = true;
                all_on_state = x["data"]["all_on"];
              if (is_target_all_on) {
                if (all_on_state) {
                  for(const auto& pair : switch_map) {
                    auto sw = pair.second;
                    sw->turn_on();
              bool is_target_all_off = false;
              bool all_off_state = false;
              if (x.containsKey("data") && x["data"].containsKey("all_off")) {
                is_target_all_off = true;
                all_off_state = x["data"]["all_off"];
              if (is_target_all_off) {
                if (all_off_state) {
                    sw->turn_off();
i have updated esphome-tuya-iot plugin to 1.2.2  so need to modify yaml:
1: esp32 framework MUST use esp-idf
2. on_event lambda changed.
you can test with this new yaml modified.
# Basic Config
#  platform: ESP32
#  board: esp32dev
  - source:
      type: git
      ref: v1.2.2
#    type: esp-idf
#    type: arduino
    type: esp-idf  # Важно изменить на arduino
    version: latest
  encryption:
mqtt:
ota:
  - platform: esphome
wifi:
  ap:
captive_portal:
time:
  sda: 4
  scl: 15
    address: 0x24
    address: 0x22
    on_turn_on:
    on_turn_off:
      mode: OUTPUT
    on_turn_on:
    on_turn_off:
      mode: OUTPUT
    on_turn_on:
    on_turn_off:
      mode: OUTPUT
    on_turn_on:
    on_turn_off:
      mode: OUTPUT
    on_turn_on:
    on_turn_off:
      number: 4
      mode: OUTPUT
    on_turn_on:
    on_turn_off:
      number: 5
      mode: OUTPUT
      number: 4
      number: 5
#switch:
#  - platform: gpio
#    pin: 25
#    id: switch_test_1
#    on_turn_on:
#    on_turn_off:
#  - platform: gpio
#    pin: 26
#    id: switch_test_2
#    on_turn_on:
#    on_turn_off:
tuya_iot:
  product_id: xp***lm
  device_id: 26***3j
  on_event:
      then:
                { 1, id(light1) },
                { 2, id(light2) },
                { 3, id(light3) },
                { 4, id(light4) },
                { 5, id(light5) },
                { 6, id(light6) },
                std::string key = "output" + std::to_string(i);
                if (x["data"][key].is<bool>()) {
                  output_state = x["data"][key].as<bool>();
                  output_number = i;
                  break;
                  if (output_state) {
                    sw->turn_on();
                  } else {
                    sw->turn_off();
              if (x["data"]["all_on"].is<bool>()) {
                all_on_state = x["data"]["all_on"].as<bool>();
                if (all_on_state) {
                    sw->turn_on();
              if (x["data"]["all_off"].is<bool>()) {
                all_off_state = x["data"]["all_off"].as<bool>();
                    sw->turn_off();
new yaml download:
.txt   a6-test-new.txt (Size: 8.04 KB / Downloads: 292)
Спасибо. Теперь возник вопрос, как устройство добавить в SmartLife/Tuya приложение. Ранее добавлял через QR-код, который формировался в KCS прошивке.
А как получить QR-код для прошивки, написанной в ESPHome?
do you have bought tuya license, we have send you "bind code" by email. you can use qrcode online guide, convert the "bind code" to qrcode. if you don't know how to make qrcode. you can send us your "bind code", we create qrcode for you.
Send to web@kincony.com my license
"qrcode online guide" - post link?
ok
