09-15-2023, 08:34 AM
(This post was last modified: 09-15-2023, 08:38 AM by KinCony Support.)
KC868-A16 wiring diagram
I've connected 24V in the output, but the output is only 19V, when high. Like this I can't connect any 24V relay. Is it correct like this?
Also I've conneced like this and I only press 1 output but 2 outputs activate the relay
10-05-2023, 10:45 AM
do you have connect 24v dc work as A16's power supply? all voltage in ports you have connected are dc24v?
10-05-2023, 10:49 AM
10-06-2023, 12:46 AM
all connect with DC24v power supply.
10-06-2023, 05:41 AM
10-06-2023, 07:47 AM
yes, A16 power supply also support use DC24v. it support dc12-24v
10-07-2023, 12:13 AM
ok, before we use for 12v, but later we have updated PCB support dc12-24v work voltage.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (10-07-2023, 12:13 AM)admin Wrote: ok, before we use for 12v, but later we have updated PCB support dc12-24v work voltage. I just got my 2 boards today and I just wanted to make sure I understand this right. I have KC868-A16 Rev 1.6. And I want to use digital inputs and outputs in a 24V system. So I can power the board with 24V and use 24V on IO Ports? The board says 12V on the power connector... but I can connect safely 24V? Thanks!! |
| 1 Guest(s) |
