B16 password reset
Hello, I try to login to B16 default web UI (http://192.168.4.1/login.html) and enter admin/admin password.
Receive Password incorrect error.
I don't remember if I changed the password, so I need to reset it do default.
Tried to push DL and Reset buttons for 10+ seconds, the device reboots, but admin/admin is still not correct.
Also tried admin without a password, also tried admin/jingkong - still not getting access.
what firmware version you have downloaded?
(11-17-2025, 02:04 AM)admin Wrote: what firmware version you have downloaded?
My B16 already came with some firmware, I didn't download a new one.
The problem is solved. I had to push longer. I managed to push DL button for more than 15 seconds and it worked, after reboot login/password was admin/admin.
Thanks.
ok. But new B16 controller you should download KCS v3 firmware by USB-C cable firstly.
(11-17-2025, 06:43 AM)admin Wrote: ok. But new B16 controller you should download KCS v3 firmware by USB-C cable firstly.
And where can I find firmware for B16? I can only see topic for B16M
https://www.kincony.com/forum/showthread.php?tid=8687
chose B16
(11-19-2025, 10:59 PM)admin Wrote: https://www.kincony.com/forum/showthread.php?tid=8687
chose B16
Thanks.
Successfully updated from 3.11 to 3.15 with:
esptool --chip esp32-s3 --port /dev/ttyACM0 write-flash 0x0 KCS_B16_V3.15.0.bin
