KC868-HxB series Smart Controller
Threads
- KC868 H32B + Switch terminal board + relay status over HTTP (6 Replies)
- KC868-HA RS485 adapter board firmware and download tool (0 Replies)
- How to appear MODBUS energy meter data to Home assistant (3 Replies)
- KC868-H8 update firmware (3 Replies)
- KC868-H8B input minimum time to activate (14 Replies)
- WebUI over wifi STA mode (3 Replies)
- Double/long click (19 Replies)
- How to use "arduino library" for KC868-H32B Pro (0 Replies)
- Switch terminal board H16B relay default controll (7 Replies)
- Help H32B Reset (14 Replies)
- Switch Terminal Board Failure?? (1 Reply)
- Home Automation design (2 Replies)
- KC868-H32BS high temperature problem (1 Reply)
- firmware update tool for KC868-D16 Dimmer Controller (0 Replies)
- How to return my password account application smart home (1 Reply)
- kincony_kc-H868B_relay32B HomeAssistant Mqtt Not Working After 2022.12.0 Update (1 Reply)
- proplem mqtt sensor configration (1 Reply)
- KC868-D8 (10 Replies)
- KC868-D8 Dimmer 1-10V, logarithmic (3 Replies)
- KC868-COL automatic control multi controllers by RS485 and RS232 (5 Replies)
- HMI display control (1 Reply)
- Help needed/wanted? (45 Replies)
- MANAGE HEX STRING COLB (4 Replies)
- switch terminal board or Dimmer controller remoter's battery (0 Replies)
- Reconexão após perda do sinal da internet. (1 Reply)
- Kincony KC868-H32B Hang with momentary Switches (9 Replies)
- Dimmer D8 lost Ethernet connection after reset (3 Replies)
- COLB RS485 BAUD RATE (15 Replies)
- KC868 H32B in node red and home assistant (1 Reply)
- KC868 H32B in home assistant (4 Replies)
- analog sensor 0-5V COL (14 Replies)
- Node-Red and Mosquitto on Windows 11 PC (5 Replies)
- KC868-H32 controlled by Raspberry pi (6 Replies)
- button switch module for KC868-Hx (7 Replies)
- H32B and H16B Digital input (13 Replies)
- Basic IFTTT commands (4 Replies)
- COLB MQTT-RS485 (1 Reply)
- Button switch module directly connected to PC with home assistant and Node Red (9 Replies)
- Dimmer D8 (1 Reply)
- how to set KC868-COLB for KBOX android phone app remote control by internet via MQTT (0 Replies)
- H32BS 24vdc output (2 Replies)
- Delay Scene (4 Replies)
- Col B wifi config (1 Reply)
- KC868-32BS -ve/ground output (4 Replies)
- H32B and 32 input panel stops communicating (5 Replies)
- KC868-32BS state from wall switch (5 Replies)
- KC868-H32 KW LATEST FIRMWARE (3 Replies)
- KC868-16B latest firmware (1 Reply)
- Voltage digital input colb (1 Reply)
- KC868 H32B latest firmware (1 Reply)
