Smart Distribution Box Solution
Powered by KinCony B32M Controller + N30 Energy Meter
The KinCony Smart Distribution Box combines the powerful B32M controller and N30 Energy Meter to create a professional-grade intelligent power management solution for homes, villas, offices, RVs, hotels, and industrial automation projects.
With cloud connectivity, local control, energy monitoring, voice assistant integration, and open IoT protocols, users can remotely manage and automate every electrical circuit easily from anywhere in the world.
Box size: 500mm*1050mm*140mm
weight: 30KG
Key Features
Multi-Platform Smart Home Integration
Compatible with major smart home ecosystems:
- Tuya Smart App
- Amazon Alexa App
- Google Home App
- Home Assistant
- Apple HomeKit
Control lights, power circuits, pumps, HVAC systems, and appliances from your preferred platform.
Remote Control Anywhere
Access and control your distribution box remotely through the internet.
Whether you are at home, in the office, or traveling overseas, you can securely switch electrical circuits ON/OFF anytime using mobile apps or cloud services.
Local LAN Control Without Internet
Even if the internet connection is unavailable, the system continues working perfectly within the local network.
- Control relays locally
- Monitor device status
- Execute automation tasks
- Access Home Assistant locally
This ensures higher reliability and uninterrupted operation.
Real-Time Energy Monitoring
Using the N30 Energy Meter, users can monitor:
- Voltage
- Current
- Power
- Energy consumption
- Electricity usage history by home assistant
Energy data can be viewed remotely through:
- Home Assistant dashboards
- KinCony Cloud platform
Perfect for smart energy management and electricity cost analysis.
Flexible Timer & Automation Functions
- Daily timer control
- Weekly schedules
- Delayed switching
- Scene automation
Ideal for lighting systems, irrigation, HVAC, and industrial control.
Alarm & Notification Push Messages
Receive instant alerts when important events occur:
- Overcurrent alarm
- Power outage notification
- Device abnormal status
- Security alerts
Notifications can be pushed directly to mobile apps and smart home platforms.
One-Key ALL ON / ALL OFF Control
Quickly switch all circuits ON or OFF with a single button or scene command.
- Leaving home mode
- Emergency shutdown
- Energy-saving mode
- Night mode
Voice Control Support
Hands-free control with popular smart speakers:
- Amazon Alexa
- Google Assistant
- Yandex Alice
Examples:
- “Alexa, turn on living room lights.”
- “Hey Google, turn off all circuits.”
- “Alice, switch on air conditioner.”
MQTT Auto Discovery for Home Assistant
Supports MQTT Auto Discovery, allowing Home Assistant to automatically detect and configure devices.
- Faster setup
- No manual entity creation
- Cleaner integration
- Beginner-friendly installation
Open IoT Protocols & Developer Friendly
The system supports multiple open communication protocols:
- MQTT
- HTTP API
- Modbus
Developers can easily integrate with:
- Arduino
- ESP-IDF
- Python
- Node-RED
- Custom IoT platforms
Perfect for DIY makers, system integrators, and industrial projects.
Compatible with Multiple Wall Switch Types
- Momentary push buttons
- Traditional wall switches
Users can freely choose the preferred switch style for their installation.
Emergency Manual Control
If the smart controller becomes damaged or offline, users can still manually operate the AC contactors using the physical toggle switches.
- System safety
- Reliable emergency operation
- Continuous electrical control
Ideal Applications
- Smart Homes
- Villas
- Apartments
- RV & Camper Automation
- Hotels
- Offices
- Industrial Automation
- Energy Management Systems
- Smart Buildings
Why Choose KinCony Smart Distribution Box?
- Remote + Local Control
- Professional Energy Monitoring
- Smart Voice Assistant Integration
- Open Protocols for Developers
- Home Assistant Ready
- Cloud + LAN Dual Operation
- Reliable Manual Backup Control
- Flexible Automation & Scheduling
System Core Hardware
- KinCony B32M Smart Controller
- KinCony N30 Energy Meter
- AC Contactors
- Smart Relay Outputs
- LAN/WiFi/Cloud Connectivity
Build Your Professional Smart Electrical System Today
The KinCony Smart Distribution Box delivers a powerful combination of smart home integration, industrial reliability, remote accessibility, and open-platform flexibility — making it an ideal solution for both residential and commercial automation projects.
Here are parts list and order links, You can DIY by yourself:
1. KinCony B32M smart controller: 1pc
https://shop.kincony.com/products/esp32-smart-controller-b32m-32ch-mosfet
2. KinCony N30 controller: 1pc
https://shop.kincony.com/products/30-channel-esp32-ac-lora-energy-meter-n30
3. DC24V 6A power supply:1pc
https://shop.kincony.com/products/mw-din-rail-switch-dc-power-supply?variant=47841934966949
4. 25A DC Contactor: 32pcs
https://shop.kincony.com/products/ac-dc-contactor
5. 1P 20A MCB:32pcs
https://shop.kincony.com/products/miniature-circuit-breaker-mcb
6. 2P 63A MCB:1pc
7. CT sensor:30pcs
https://shop.kincony.com/products/25a-current-transformer-for-kincony-m30-m16-energy-meter-board
8. Fuse:1pc
https://shop.kincony.com/products/1pc-fuse-32a-500v-ac-fusible
9. EARTH and GROUND terminal:3pcs
https://shop.kincony.com/products/5-hole-row-ground-copper-bar-for-distribution-box
10. Short circuit strip
https://shop.kincony.com/products/short-circuit-strip-kf2edg-5-08mm-copper-sheet-eb10-5-insulation-short-connector-brass
11. cold pressure line connector
https://shop.kincony.com/products/insulation-sheath-terminal-row-cold-pressure-line-connector-voltage-terminal
12. Extender Antenna
https://shop.kincony.com/products/2-4ghz-433mhz-extender-antenna-8dbi-antena-gsm-sma-male-connector
