KinCony KC868-A8v3 ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 8 channel digital input and 8 channel relay output, 4 channel 1-wire GPIOs. One SD card using SPI bus. KinCony KC868-A8v3 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address. A8v3 have RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32S3 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. A8v3 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support Apple HomeKit.
Model No. KinCony KC868-A8v3
Description: KinCony 8 Channel ESP32-S3 Relay Controller – A8v3
Power supply: 12/24V DC
PCB Size: 105mm*148mm
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD, i2c extender
SD Card: SPI bus
Installation method: DIN RAIL (with plastic shell)
LCD: SSD1306 I2C display
Outputs:
8CH Relay Outputs, every channel relay’s load MAX250V10A COM,NO,NC
Inputs:
3 buttons: S1:Tuya S2:ESP32 Reset S3:ESP32 Download (GPIO0)
