KinCony Pi5M8 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home & Industrial Automation
Product Overview
KinCony Pi5M8 is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates 8-channel MOSFET outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly manages MOSFET outputs, digital inputs, analog inputs, PWM outputs, and serial communication ports, making it easy to deploy automation solutions using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.
Pi5M8 is ideal for controlling DC loads such as LED strips, solenoid valves, DC motors, industrial actuators, and custom automation equipment.
Key Features
- 8-channel MOSFET outputs
- 8 optocoupler-isolated digital inputs
- 2-channel PWM outputs
- 2 × DC 0-5V analog inputs
- 2 × 4-20mA analog inputs
- 20 free GPIO expansion pins
- Gigabit Ethernet support
- M.2 M-Key PCIe expansion socket
- SSD1306 I2C OLED display
- Industrial DIN rail aluminum enclosure
- Designed for smart home and industrial automation applications
