KinCony DM4 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. DM4 include DS3231 high precision RTC clock chip. OLED display will show wifi and ethernet IP address and Tuya connection state. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. DM4 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
Model No. KinCony DM4
Description: KinCony 4 Channel ESP32-S3 Smart Dimmer Controller – DM4
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
OLED: SSD1306 I2C display
Outputs:
4CH 0-10v Outputs.
Inputs:
4CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
