KinCony TS (Tiny Sensor) made by SHT30 temperature and humidity sensor inside.
product size: 20mm*18mm
power supply: DC 9-36V
temperature: -40℃– +125℃
humidity: 0–100% RH
temperature accuracy: 0.1℃
humidity accuracy: 0.1% RH
communication: RS485
RS485 baud rate: 9600/14400/19200/38400/56000/57600/115200 bps
RS485 address: 1–255 editable
LED D3: power LED
LED D4: running LED (blink with running)
Jumper: RS485 Terminating resistor jumper (make sure last RS485 slave device enable it)
You can read temperature and humidity by PC software via RS485 USB adapter.
you can set KinCony TS by different address and Baud.
