KinCony Pi5R32 – Raspberry Pi CM5 DIN Rail 32-Channel Relay Controller for Smart Home & Industrial Automation
Product Overview
KinCony Pi5R32 is a powerful Raspberry Pi-based IoT gateway and automation controller designed for smart home, building automation, and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates 32 relay outputs, 32 optocoupler-isolated digital inputs, analog inputs, PWM outputs, RS232/RS485 communication interfaces, and multiple expansion interfaces into a rugged DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly controls all relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces. Users can easily deploy automation projects using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.
Pi5R32 is ideal for large-scale automation projects requiring high-density I/O control while maintaining the flexibility of a Raspberry Pi platform.
Key Features
- 32-channel relay outputs
- 32-channel optocoupler-isolated digital inputs
- 2-channel PWM outputs
- 2 × DC 0-5V analog inputs
- 2 × 4-20mA analog inputs
- 20 free GPIO expansion pins
- Gigabit Ethernet support
- M.2 M-Key PCIe expansion socket
- SSD1306 I2C OLED display
- Industrial DIN rail aluminum enclosure
- Designed for smart home and industrial automation systems
Product Specifications
| Item | Specification |
| Model | KinCony Pi5R32 |
| Description | KinCony Automation Local Server – Pi5R32 |
| Processor | Raspberry Pi Compute Module 5 |
| Dimensions | 298mm × 105mm × 58mm |
| Installation | DIN Rail |
| Material | Aluminum Shell |
| Power Supply | DC 12V–24V |
| Operating Temperature | -20°C to 70°C |
| Operating Humidity | 20%–80% |
| Ethernet | 1 × RJ45 Gigabit Ethernet (IPv4/IPv6) |
| USB | 2 × USB 3.0 |
| HDMI | 1 × Full-size HDMI 2.0 |
| USB-C | 1 × USB-C |
| microSD | 1 × microSD Card Slot (Lite version only) |
| RS232 | 1 Port |
| RS485 | 1 Port |
| OLED Display | SSD1306 I2C OLED |
| Expansion | M.2 M-Key PCIe Socket |
| GPIO Expansion | CM5 GPIO Extender |
| Cooling | Heatsink + Fan |
Relay Output Specifications
| Relay Channels | 32 |
| Contact Type | COM / NO |
| Maximum AC Load | AC250V / 7A per channel |
| Maximum DC Load | DC30V / 7A per channel |
| Applications | Lighting, HVAC, pumps, contactors, motors, industrial equipment |
Digital Input Specifications
| Input Channels | 32 |
| Isolation | Optocoupler Isolation |
| Signal Type | Dry Contact |
| Maximum Cable Length | 500 meters |
| Logic “1” | DC 0V |
| Logic “0” | DC 12V |
Analog Inputs
| Type | Channels |
| Voltage Input | 2 × DC 0-5V |
| Current Input | 2 × 4-20mA |
PWM Outputs
| PWM Channels | 2 |
Communication Interfaces
- 1 × Gigabit Ethernet
- 1 × RS232
- 1 × RS485
- 2 × USB 3.0
- 1 × HDMI 2.0
- 1 × USB-C
- 1 × microSD Card Slot
- 2 × PWM Outputs
- 2 × 0-5V Analog Inputs
- 2 × 4-20mA Analog Inputs
Free GPIO Expansion
The Pi5R32 provides 20 free GPIOs from the Raspberry Pi CM5 module for custom hardware expansion and software development.
GPIO21, GPIO20, GPIO16, GPIO01, GPIO07, GPIO08, GPIO25, GPIO24, GPIO23, GPIO18,
GPIO26, GPIO19, GPIO06, GPIO00, GPIO11, GPIO09, GPIO10, GPIO22, GPIO27, GPIO17
Default CM5 Configuration
- CM5004000
- 4GB RAM
- Lite Version
- No WiFi
- No Bluetooth
Important Notes
microSD Card Support
If you are using a CM5 module with onboard eMMC storage, the microSD card slot cannot be used.
The microSD card slot is only available when using a CM5 Lite module.
Programming the CM5
To access the CM5 eMMC or microSD storage through USB-C:
- Connect the Pi5R32 to your computer using a USB-C cable.
- Run the Raspberry Pi rpiboot utility.
- The eMMC or microSD storage will appear as a removable drive.
- Flash Raspberry Pi OS or other Linux distributions directly.
Package Options
Bundle A
- Pi5R32 Mainboard
- Without CM5 Module
- Heatsink
- Cooling Fan
Bundle B
- Pi5R32 Mainboard
- CM5 Module (CM5004000)
- 4GB RAM Lite Version
- Heatsink
- Cooling Fan
Typical Applications
- Home Assistant Local Server
- Node-RED Automation Controller
- Industrial Automation Systems
- Smart Building Control
- Lighting Automation
- HVAC Management
- Pump and Motor Control
- Factory Equipment Control
- Energy Management Systems
- MQTT and Modbus Gateway
- IoT Edge Computing Applications
Software Support
- Home Assistant
- Node-RED
- Raspberry Pi OS
- MQTT
- Modbus RTU/TCP
- Docker
- Python
- Linux-based Automation Software
Why Choose Pi5R32?
The KinCony Pi5R32 combines the computing power of Raspberry Pi CM5 with 32 industrial relay outputs, 32 isolated digital inputs, analog inputs, PWM outputs, and industrial communication interfaces in a single DIN rail enclosure.
Unlike traditional PLCs or relay controllers, Pi5R32 can run Home Assistant, Node-RED, Docker containers, MQTT brokers, and custom Linux applications directly on the device, making it a complete automation server and high-density I/O controller.
Whether you are building a smart home, commercial building automation system, industrial control cabinet, or IoT gateway, Pi5R32 offers a powerful, reliable, and expandable automation platform.
Related technical information
KinCony Pi5R32 Raspberry Pi iot gateway CM5 GPIO pins define
