KinCony TR ESP32-S3 sensor convertor module based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 4 channel 1-wire GPIOs and RS485 interface. Many free GPIOs on PCB. It convert MAX 4 channel sensor (DS18B20/DHT11/DHT22) temperature and humidity value to RS485 modbus protocol. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. TR use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support Apple HomeKit.
Model No. KinCony TR
Description: KinCony ESP32-S3 temperature humidity sensor modbus convertor – TR
Power supply: 12-24V DC
interfaces: WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Inputs:
3 buttons: 1:ESP32-S3 Reset 2:ESP32-S3 Download
Free GPIOs:
GPIO4 GPIO1
GPIO5 GPIO2
GPIO6
GPIO18
GPIO8 GPIO42
GPIO3 GPIO41
GPIO21 GPIO40
GPIO47 GPIO39
GPIO48 GPIO38
software solution:
1. download KinCony KCS firmware, so that work with multi protocol: HTTP, MQTT, TCP, RS485 modbus. “KCS” support IFTTT function work locally without internet. It also support use by KinCony cloud server. KCS v3 support home assistant auto discovery function by MQTT, so without any config file for home assistant.
3. download tasmota firmware.
temperature humidity sensor convertor – TR RS485 Modbus protocol see here
