KinCony Pi5R16 – Raspberry Pi CM5 DIN Rail IoT Gateway for Smart Home & Industrial Automation
Product Overview
KinCony Pi5R16 is a powerful Raspberry Pi–based IoT gateway designed for smart home automation and industrial control applications. Built around the Raspberry Pi Compute Module 5 (CM5), it integrates relay outputs, opto-isolated digital inputs, analog inputs, RS232/RS485 communication, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.
Pi5R16 is ideal for users who want to build local automation systems using platforms such as Home Assistant, Node-RED, MQTT, Modbus, or custom Linux applications.
The CM5 module directly manages all relays, digital inputs, analog inputs, PWM outputs, and serial communication ports, making development and deployment simple and flexible.
Key Features
- Raspberry Pi Compute Module 5 (CM5) integrated
- 16-channel relay outputs
- 16-channel optocoupler-isolated digital inputs
- 2-channel PWM outputs
- Analog input support:
- 2 × DC 0–5V
- 2 × 4–20mA
- 20 free GPIO expansion ports
- Gigabit Ethernet support
- M.2 PCIe expansion socket
- DIN rail aluminum enclosure design
- SSD1306 I2C OLED display
- Designed for industrial and smart home automation
