KinCony Pi5R8 – Raspberry Pi CM5 DIN Rail Relay Controller for Smart Home & Industrial Automation
Product Overview
KinCony Pi5R8 is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates relay outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and expansion interfaces into a compact DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly manages relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces, making it easy to deploy automation solutions using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software.
Pi5R8 is an ideal platform for smart homes, industrial automation, energy management systems, and IoT edge computing applications.
Key Features
- 8-channel industrial relay outputs
- 8 optocoupler-isolated digital inputs
- RS232 and RS485 communication interfaces
- 2-channel PWM outputs
- 2 × DC 0-5V analog inputs
- 2 × 4-20mA analog inputs
- 20 free GPIO expansion pins
- Gigabit Ethernet support
- M.2 PCIe expansion socket
- SSD1306 OLED display
- Industrial aluminum DIN rail enclosure
- Ideal for smart home and industrial automation projects
