KinCony Pi5 is a Raspberry Pi CM5 server for smart home automation and industrial automation control. It can use for home assistant local server. It’s a Linux computer, you can install software by yourself, such as Node red. The product default CM5 version is CM5004000. It without Bluetooth and wifi, RAM:4G Lite version.
Model No. KinCony Pi5
Description: KinCony Automation Local Server – Pi5
Power supply: 12-24V DC
Processor: Raspberry Pi Compute Module 5
interfaces: Ethernet(RJ45)-LAN 1000Mbps IPv4/IPv6,USB-C
Installation method: DIN RAIL
2 × USB 3 sockets
microSD card socket for CM5 Lite modules
M.2 M key PCIe socket
1 × full-size HDMI 2.0 connectors
DIP SWITCH for jumpers
Order bundles:
Bundle A: Pi5 without CM5
Bundle B: Pi5 with CM5(CM5004000):RAM:4G-Lite
note:
if you are using CM5 with eMMC version, so can’t use SD card. SD card only use for CM5 lite version.
if you want download firmware to eMMC or SD card by USB-C cable in your computer. You should run rpiboot EXE file in your PC. So that SD card or eMMC will work as a windows driver.
