KinCony KC868-A16v3 ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 channel digital input and 16 channel digital output, 3 channel 1-wire GPIOs, 4 channel analog input ports. 3 free GPIO on PCB beside ESP32-S3 module. One SD card using SPI bus. KinCony KC868-A16v3 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address. A16v3 have RS485 port and RF433MHz RF sender / receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. A16v3 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support Apple HomeKit.
Model No. KinCony KC868-A16v3
Description: KinCony 16 Channel ESP32-S3 Mosfet Controller – A16v3
Power supply: 12/24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD, i2c extender
SD Card: SPI bus
Installation method: DIN RAIL (with plastic shell)
LCD: SSD1306 I2C display
Outputs:
16CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
4CH analog input DC0-5V (A1,A2,A3,A4)
2 buttons: S1:ESP32 Reset S2:ESP32 Download (GPIO0)
1-Wire GPIO: 3CH (with pull-up resistance on PCB)
RF sender / receiver socket: 433MHz RF receiver
improvements based on old KC868-A16:
1. use by ESP32-S3-WROOM-1U (N16R8) big memory size chip. support extend wifi antenna by IPEX port.
2. add NTC power protect circuit, if polar exchange will not burn board.
3. replace LAN8720A with W5500 ethernet chip, more stable.
4. fixed RF receiver circuit bug.
5. add DS3231 high-precision RTC clock.
6. support KinCony new cloud service.
7. support KCS v3 support Apple HomeKit and Loxone Miniserver system.
8. add SSD1306 LCD display
9. add SD card to save LOG
10. support KCS v3 newest firmware more powerful functions.
Wiring Examples:
software solution:
1. download KinCony KCS v3 firmware, so that work with multi protocol: HTTP, MQTT, TCP, RS485 modbus, Tuya app (need to buy tuya license), config OUTPUT for “momentary” and “interlock” group functions. “KCS” v3 support IFTTT function work locally without internet. It also support use by KinCony cloud server. KCS v3 support home assistant auto discovery function by MQTT, so without any config file for home assistant.
3. download tasmota firmware.
4. write your own Arduino code for your own requirements.
installed SSD1306 LCD and 433MHz RF receiver / sender.
back of PCB.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7614
KCS v3 firmware download: https://www.kincony.com/forum/forumdisplay.php?fid=75
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=7615
ESPHome official supportted list: https://devices.esphome.io/devices/KinCony-KC868-A16v3
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=68
Design detail photos:
GPIO39,GPIO40,GPIO41 free GPIO for user connect with other device.
digital input with optocoupler isolation circuit
power circuit with NTC. add NTC power protect circuit, if polar exchange will not burn board.
RF 433MHz receiver / sender. fixed RF receiver circuit bug based on KC868-A16v1 PCB.
