KinCony F4 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 4 manual control switch buttons can turn ON/OFF relay even if system is broken. 4 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F4 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F4 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware(tasmota total support MAX 32channel INPUT+OUTPUT ports) for smart home automation DIY. F4 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant.
Model No. KinCony F4
Description: KinCony 4 Channel ESP32-S3 Removable Relay Controller – F4
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
4CH OMRON removable relay, every channel have “COM”(common) and “NO”(normal open) ports.
MAX load 250VAC/16A 30VDC/16A
Inputs:
4CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
software solution:
3. download tasmota firmware.
Wiring Examples:
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=8709
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=8710
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=98
ESPHome official supportted list: https://devices.esphome.io/devices/KinCony-F4/
manaul control switch turn on/off relay even if controller is broken
ESP32-S3-WROOM-1U (N16R8) CPU: large memory size with PSRAM.
OptoCoupler circuit with digital input ports
high-precision DS3231 RTC clock with battery socket
SMA socket for extend antenna.
tuya wifi module, support voice control by alexa and google home speaker directly.
W5500 high quality ethernet chip
Order bundles:
Bundle A: F4
Bundle B: F4 + USB-C cable+ power supply
