KinCony B24M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 24 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B24M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B24M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B24M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant.
Model No. KinCony B24M
Description: KinCony 24 Channel ESP32-S3 Smart Controller – B24M
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
24CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
24CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
software solution:
3. download tasmota firmware.
Wiring Examples:
Order bundles:
Bundle A: B24M
Bundle B: B24M + USB-C cable+ DC12V power supply
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=8358
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=8360
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=85
Different views of the B24M:
support install on DIN RAIL
use by 10A mosfet IC
use by ESP32-S3-WROOM-1U (N16R8) big memory size chip.
OptoCoupler circuit with digital input ports
10A mosfet
