KinCony T64M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 64 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T64M have RS485 port. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. T64M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
Model No. KinCony T64M
Description: KinCony 64 Channel Tiny ESP32-S3 Smart Controller – T64M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Outputs:
64CH MOSFET Outputs, every channel use MAX 4A driver IC
Inputs:
64CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
free GPIO: 3CH (connect with ESP32S3 pin directly)
software solution:
1. download KinCony KCS v3 firmware, so that work with multi protocol: HTTP, MQTT, TCP, RS485 modbus, config OUTPUT for “momentary” and “interlock” group functions. if you want local voice control without internet, you can add KinCony AS voice assistant. “KCS” support IFTTT function work locally without internet. It also support use by KinCony cloud server. KCS v3 support home assistant auto discovery function by MQTT, so without any config file for home assistant.
3. write your own Arduino or ESP-IDF code for your own requirements.
Order bundles:
Bundle A: T64M
Bundle B: T64M + USB-C cable+ power supply
Wiring Examples:
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7996
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=7997
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=81
Different views of the T64M:
w5500 ethernet chip
ESP32-S3-WROOM-1U (N16R8) large memory PSRAM module.
PCF8575 i2c extender chip.
