KinCony F8 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 8 manual control switch buttons can turn ON/OFF relay even if system is broken. 8 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 1 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F8 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F8 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. F8 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. F8 support Apple HomeKit, easy to use directly. Support save state LOG to SD Card. It use by local RTC clock, use timer work without internet. F8 support to use KinCony cloud server service, so that you can remote control and monitor your device by internet using mobile phone or computer web browser. note: (buy from KinCony Official Shop have KinCony cloud server 2 years free)
Model No. KinCony F8
Description: KinCony 8 Channel ESP32-S3 Removable Relay Controller – F8
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
8CH OMRON removable relay, every channel have “COM”(common) and “NO”(normal open) ports.
MAX load 250VAC/16A 30VDC/16A
Inputs:
free GPIO: 1CH (without pull-up resistance on PCB, connect with ESP32 pin directly)
software solution:
3. download tasmota firmware.
4. write your own Arduino code for your own requirements.
5. It is recommended to use home assistant and Tuya mobile phone app at the same time. So that remote control by internet using Tuya app, local control by LAN using home
Wiring Examples:
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=7983
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=7984
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=79
ESPHome official supportted list: https://devices.esphome.io/devices/KinCony-F8
YouTube video tour: https://youtu.be/Qlhkwwhnf6o
use by removable terminal
ESP32-S3-WROOM-1U (N16R8) CPU: large memory size with PSRAM.
tuya wifi module, support voice control by alexa and google home speaker directly.
OptoCoupler circuit with digital input ports
high-precision DS3231 RTC clock with battery socket
W5500 high quality ethernet chip
NTC surge protection circuit
RS485 TVS protect circuit
SMA socket for extend antenna.
