KinCony B4M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B4M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B4M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B4M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. B4M support Apple HomeKit, easy to use directly. Support save state LOG to SD Card. It use by local RTC clock, use timer work without internet. B4M support to use KinCony cloud server service, so that you can remote control and monitor your device by internet using mobile phone or computer web browser. note: (buy from KinCony Official Shop have KinCony cloud server 2 years free)
Model No. KinCony B4M
Description: KinCony 4 Channel ESP32-S3 Smart Controller – B4M
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
4CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
4CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
software solution:
1. download firmware by ESPHome, integrate to home assistant or use by web service.
2. download tasmota firmware.
3. write your own Arduino code for your own requirements.
Order bundles:
Bundle A: B4
Bundle B: B4 + USB-C cable+ DC12V power supply
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=8912
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=8939
ESPHome official supportted list: https://devices.esphome.io/devices/kincony-b4m/
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=100
more details of photo:
manual control buttons work without software, if controller is broken, also can turn on/off output manually.
