KinCony DM8 8CH ESP32 Dimmer Board released
KinCony DM8 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One…
[vc_row][vc_column]
KinCony DM32 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One…
KinCony DM4 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One…
KinCony B32M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports.…
KinCony Pi5 is a Raspberry Pi CM5 server for smart home automation and industrial automation control. It can use for home assistant local server. It’s a Linux computer, you can…
KinCony Pi5 is a Raspberry Pi CM5 server v2 for smart home automation and industrial automation control. It can use for home assistant local server. It’s a Linux computer, you…
KinCony B4M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports.…
KinCony B4 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 4 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card…
KinCony have B,F,T,A,E,N,M,DM,Pi5,Pi4 series products. What’s difference? “A” is old version, made by ESP32 module, low cost, it’s cheaper. “B” is new version in stead of A series products ,…
KinCony E8v3 RS485 Modbus Din Rail Relay Module based on ARM CPU. It have 8 manual control switch buttons can turn ON/OFF relay even if system is broken. The manual…
KinCony E24v3 RS485 Modbus Din Rail Relay Module based on ARM CPU. It have 24 manual control switch buttons can turn ON/OFF relay even if system is broken. The manual…
KinCony F4 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 4 manual control switch buttons can turn ON/OFF relay even if system is broken. 4 channel removable…
KinCony E16v3 RS485 Modbus Din Rail Relay Module based on ARM CPU. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. The manual…
KinCony F32 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. 32 channel removable…
KinCony TR ESP32-S3 sensor convertor module based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 4 channel 1-wire GPIOs and RS485 interface. Many free GPIOs on PCB. It convert MAX 4…
We have designed 30 Channel ESP32 energy monitor board – N30 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The…
We have designed 20 Channel ESP32 energy monitor board – N20 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The…
We have designed 10 Channel ESP32 energy monitor board – N10 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The…
KinCony AIO Hybrid ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It’s ALL IN ONE module. It have 5 manual control switch buttons can turn ON/OFF relay even if…
KinCony DM16 ESP32 smart dimmer controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel DC 0-10v output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One…
KinCony B8 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card…
KinCony B24 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 24 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card…
KinCony B24M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 24 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports.…
We have designed 60 Channel ESP32 energy monitor board – N60 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The…
Note: This document use for KinCony KCS v3 firmware smart controller with Zigbee function. 1. Download “KCS” v3 firmware to KinCony ESP32-S3 series board. a. Download “ESP32 download tool” from…
we have designed Z1 by ESP32S3 + Tuya ZSU Zigbee 3.0 module. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. it support use by ESPHome for home assistant for smart home…
Note: This document use for KinCony KCS v3 firmware smart controller with Zigbee function. 1. Download “KCS” firmware to KinCony ESP32-S3 series board. a. Download “ESP32 download tool” from https://www.kincony.com/wp-content/uploads/2022/08/flash_download_tool_3.9.2.zip…
KinCony T128M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 128 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T128M have RS485 port. You…
KinCony T64M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 64 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T64M have RS485 port. You…
KinCony T32M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T32M have RS485 port. You…
KinCony B8M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports.…
KinCony KC868-A8v3 ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 8 channel digital input and 8 channel relay output, 4 channel 1-wire GPIOs. One SD card using…
KinCony F8 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 8 manual control switch buttons can turn ON/OFF relay even if system is broken. 8 channel removable…
KinCony KC868-A2v3 ESP32-S3 smart controller based on ESP32-S3-WROOM-1 (N16R8) wifi chip. It have 2 channel digital input and 2 channel relay output, 2 channel 1-wire GPIOs, 4 free GPIO on…
KinCony TA (Tiny Alarm System) ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip and Tuya module. It have 12 channel digital input (12-zone) and 2 channel relay output for…
KinCony B16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel relay output, 7 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card…
KinCony KC868-A6v3 ESP32 smart controller based on ESP32-S3-WROOM-1 (N16R8) wifi chip. Support 6 channel relay output, 2 channel 1-wire GPIOs, 6 channel free gpio on PCB. A6v3 include DS3231 high…
KinCony KC868-A16v3 ESP32-S3 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 channel digital input and 16 channel digital output, 3 channel 1-wire GPIOs, 4 channel analog input…
KinCony T16M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 7 channel 1-wire GPIOs T16M have RS485 port. You can write any code…
KinCony TS (Tiny Sensor) made by SHT30 temperature and humidity sensor inside. product size: 20mm*18mm power supply: DC 9-36V temperature: -40℃– +125℃ humidity: 0–100% RH temperature accuracy: 0.1℃ humidity accuracy:…
KinCony T16M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 7 channel 1-wire GPIOs. T16M have RS485 port. You can write any code…
KinCony F24 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 24 manual control switch buttons can turn ON/OFF relay even if system is broken. 24 channel removable…
KinCony G1 ESP32 4G module based on ESP32-S3-WROOM-1U (N16R8) and SIMCOM SIM7600E series chip. G1 have RS485 port and many free GPIOs for user.You can write any code by Arduino…
The SIM7600E-L1C is a versatile and cost-effective 4G LTE module that integrates multiple communication functionalities, making it suitable for a wide range of IoT and M2M applications. Developed by KinCony,…
Note: This document use for KinCony KCS v3 firmware smart controller. 1. Download “KCS” firmware to KinCony ESP32-S3 series board. a. Download “ESP32 download tool” from https://www.kincony.com/wp-content/uploads/2022/08/flash_download_tool_3.9.2.zip and firmware BIN…
KinCony ESP32-S3 voice assistant based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It use by I2S INMP441 microphone and MAX98357A amplifier. SD card socket on PCB. there are WS2812B RGB LED you…
KinCony F16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. 16 channel removable…
KinCony B16M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports.…
KinCony Video Submission Campaign: Showcase Your Project and Get Rewarded! Dear Valued KinCony Customers, We’re excited to launch a new campaign where you can share how you’re using KinCony products…
We have designed ESP32 LoRa SX1278 Gateway – KinCony ALR. It support install into waterproof box. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with relay,SSD1306 LCD, 4 channel analog input,…
We have designed Logic Level Converter Module for 6 channel convert DC 0V and 12V. it can use for switch panel’s LED feedback. IF Input=0v THEN output=12V IF Input=12v THEN…
We have designed ESP32-S3 Smart IR Controller – KinCony AG8. it support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, RS232, 1-wire GPIOs, 8 channel…
We have designed new 32CH Smart Distribution Panel With Energy Monitoring. Controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip, it have 32 manual control switch buttons can turn ON/OFF relay even…
the KBOX app (iPhone and android OS), use for KinCony 2,4,8,16,32 channel relay controller. it use in local network without internet. download from here: https://www.kincony.com/document add relay controller according to…
the PC software for Windows OS, use for KinCony A32 Pro/A32/H32B Pro/H32BS/H32B/H32 32 channel relay controller. download from here: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip add 32 channel relay controller by IP address and Port.…
We have designed ESP32-S3 Core Board – KinCony S3. it’s mini PCB, support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, I2C bus, 1-wire, analog…
We have designed ESP32 SD card module – ATF. it can record data save file to SD card. It need you write arduino code. for example, you can receiver serial…
KinCony A32 Pro ESP32 relay board based on ESP32-S3-WROOM-1U (N16R8) wifi chip, it have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. Support 32…
KinCony Server16 is a Raspberry Pi iot gateway for smart home automation and industrial automation control, It have 16 channel relay, many digital input ports with optocoupler isolation. The most…
KinCony ESP32 Tuya IoT adapter V2 let relay board or IoT devices easy integrate to tuya IoT platform. We have designed by ESP32 work with Tuya module. Tuya module will…
We have designed mini ESP32 AC dimmer module – ADR. it can use for lamp change brightness or change fan motor speed. it’s easy integrate to home assistant by ESPHome.…
KinCony DI8 is PCF8574 IO Expansion i2c relay board. extend 8 channel digital input port (with optocoupler isolation circuit). digital input support use by dry contact signal. 8 LEDs show…
KinCony DO8 is PCF8574 IO Expansion i2c relay board. extend 8 channel 10A relay. manual control buttons on board can control relay ON/OFF directly without any software. manual control buttons…
We have designed 30 Channel ESP32 energy monitor open source board – M30 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation DIYer. The hardware have 30CH CT Clamp…
We have designed ESP32 Battery Monitor – KinCony MB (ESP32 16 channel DC voltage and current energy monitor) for home automation DIYer. it can easy integrate to home assistant by…
KinCony A24 esp32 board based on ESP32 wifi chip, it have manual control switch buttons can turn ON/OFF relay even if system is broken. Support 3CH K-Type thermocouple use by…
We have designed new 8CH Raspberry Pi distribution board, it’s very powerful Linux Computer, made by Raspberry Pi CM4, it have 8 channel relay output, 8 digital input ports, ethernet…
The smallest RS485 IO Module — KC868-HAv2 module. size 3cm*3cm. let your switch panel and dry contact sensor convert to RS485. KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome, easy…
We have designed ESP32 Energy Meter Relay Controller – KinCony M1 (ESP32 1 channel AC voltage and current energy monitor) for home automation DIYer. it can easy integrate to home…
KinCony A8S v2 esp32 board based on ESP32 wifi chip, it have manual control switch buttons can turn ON/OFF relay even if system is broken. Support POE module work without…
smart electrical distribution panel use Tuya phone application remote control by internet, if add SIM7600 4G module, support use Tuya app by 4G SIM card. It also support control relay…
we have designed KC868-E16P ESP32 home automation extend relay module. PCB with manual control buttons. it’s based on ESP32 , Ethernet POE + RS485 + 4CH analog input + 16CH…
we have designed KC868-AG Pro by ESP32 + Tuya + Zigbee 3.0 module, it’s easy to use ESPHome for home assistant. Now you can use home assistant and Tuya app…
We have designed KC868-M16v2 new version (ESP32 16 Channel CT Clamp Energy Monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH…
“KCS” means “KinCony Super” , V2 version have added many new functions, support local IFTTT on board, 4G SIM7600 module for remote control without internet, you can use by SMS,…
Note: This document use for KinCony smart controller: KC868-AM ASR A2 A4 A4S A6 A8 A8M A8S A16 A16S E16S A32 A32M A64 A128 AG AK AI AIO AP if…
KC868-1U is a esp32 diy pcb board use for esp32 diy project. it can install to 1U size box, let your relay controller become smart. if you have a power…
KC868-1U is a esp32 diy pcb board. it can install to 1U size box, let your relay controller become smart. if you have a power sequencer, KC868-1U will easy connect…
KinCony Server-Mini is a raspberry pi CM4 relay board for smart home automation and industrial automation control, it’s mini version of KC868-Server. Server-Mini smart controller support 8 channel relay output…
KinCony Server-Mini is a raspberry pi 4 relay board for smart home automation and industrial automation control, it’s mini version of KC868-Server. Server-Mini smart controller support 8 channel relay output…
We have designed new 16CH Raspberry Pi distribution panel, it’s very powerful Linux Computer, made by Raspberry Pi CM4, it have 16 channel relay output, 16 digital input ports, ethernet…
We have designed KC868-M16 (ESP32 16 Channel CT Clamp Energy Monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH CT Clamp…
We have designed KC868-A32M (ESP32 MOSFET Module) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 32CH MOSFET output + 4CH analog input…
We have designed KC868-A8M (ESP32 CAN Bus Board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 8CH MOSFET output + 8CH digital…
We have designed KC868-A16S (ESP32 16 channel relay board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH relay (MAX AC250V 10A)…
We have designed KC868-AIO (ESP32 All in One) board for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 32CH mosfet output + 58CH…
KC868-A2 esp32 4G relay board based on ESP32 wifi chip, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Support 4G SIM7600…
we have design this ESP32 GPIO board (KC868-A256) for home assistant. It use by ESP32-WROOM-32E, 256CH digial input ports + 256CH MOSFET output ports + 4CH analog input ports +…
we have design this ESP32 Arduino GPIOs board (KC868-A256) for home assistant. It use by ESP32-WROOM-32E, 256CH digial input ports + 256CH MOSFET output ports + 4CH analog input ports…
We have designed ESP32 IO Expansion (development) Board — KC868-AM (Mini) . it’s ESP32 module + many free GPIOs for home automation DIYer to use. 4 GPIOs in greent terminal…
We have designed ESP32 IO Expansion Board — KC868-AM (Mini) . it’s ESP32 module + many free GPIOs for home automation DIYer to use. 4 GPIOs in greent terminal already…
we have designed 8 Channel Manual Bypass Switch for smart home automation controller. If controller is broken or bad, so that can use manual control buttons for your smart system.
We have designed new 32CH smart distribution system, it’s very powerful, it have 32 channel relay output, 6 digital input ports, ethernet + Tuya WiFi + ESP32 module, work with…
We have designed new 32CH smart distribution panel, it’s very powerful, it have 32 channel relay output, 6 digital input ports, ethernet + Tuya WiFi + ESP32 module, work with…
KC868-ASR ESP32 SD card sensor record board based on ESP32 chip. It have many hardware resource for you to use. It have two channel relay, two GPIOs for temperature or…
KC868-A4S esp32 arduino board based on ESP32 wifi chip, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Use SMS or call…
KC868-A4S esp32 board based on ESP32 wifi chip, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Use SMS or call to…
“KCS” means “KinCony Super” , this is a new firmware developed by KinCony for KC868-A series products in 2023. we have released firmware for KC868-A4, KC868-A6, KC868-A8, KC868-A8S, KC868-A16, KC868-E16S,…
Note: This document use for KinCony smart controller: KC868-A4 A6 A8 A8S A16 E16S A32 A64 A128 if you want to read by PDF file, download user guide PDF file. 1.…
“KCS” means “KinCony Super” , this is a new firmware developed by KinCony for KC868-A series products in 2023. It has powerful functions and supports multiple communication protocols. It can…
Ovdje sam naišao na tajanstveni proizvod pod nazivom “ESP32 Tuya IoT adapter”, možete cijeniti originalnost njegovog izgleda s gornje fotografije. S druge strane, ime sadrži ESP32, a kao što znate, ako…
Here we came across a product called “ESP32 Tuya IoT adapter”, you can appreciate the originality of its appearance from the photo above. On the other hand, the name contains ESP32,…
Dok smo se bavili prijašnjim Kincony kontrolerima, pokušavajući ih primjeniti u pametnim projektima, Kincony također nije gubio vrijeme i objavio je još nekoliko kontrolera koji će na naše zadovoljstvo naći…
While we were dealing with the previous Kincony controllers, trying to apply them in smart projects, Kincony also no wasted time and released several more controllers that will find application…
KC102 Smart IR Controller is tuya ir universal remote product. it can use by Tuya application remote control device by internet. There are some IR code on cloud server. You…
KC102 Smart IR Controller is tuya ir universal remote product. it can use by Tuya application to remote control IR device by internet. There are some IR code on cloud…
Čini se da su mnogi Kincony kontroleri prilično moćni uređaji – ploče nevjerojatne veličine, s velikim brojem digitalnih ulaza i kontrolnih izlaza, mnoga sučelja itd., ali to vam se samo…
It seems that many Kincony controllers are quite a bit but powerful and incredible size, with a large number of digital inputs and outputs, many interfaces, etc., but this is…
Danas ćemo govoriti o rješenju dostojnom plasmana u Guinnessovu knjigu rekorda – to je kontroler Kincony KC868-A128, koji na ploči ima čak 128 digitalnih ulaza i 128 digitalnih izlaza –…
Today we will talk about a solution worthy of placement in the Guinness Book of Records – this is the Kincony KC868-A128 controller, which has as many as 128 digital…
We have designed KC868-AP. It is a ESP32 16 channel PWM dimmer board. It use PCA9685. The PCA9685 component represents a PCA9685 12-bit PWM driver. It uses I²C Bus for…
KC868-AP is a ESP32 16 channel LED dimmer board. It use PCA9685. The PCA9685 component represents a PCA9685 12-bit PWM driver. It uses I²C Bus for communication. every channel output…
We have designed the new version of “switch terminal board” — KC868-AK. This is a powerful ESP32 programmable keyborad , support by home assistant via ESPHome for home automation DIYer.…
This is a powerful ESP32 programmable keyborad , support by home assistant via ESPHome for home automation DIYer. It also can work with KinCony’s smart relay controller. let your wall…
We have designed KC868-HA RS485 button adapter, let your old switch or traditional switch become smart, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel…
Hardware diagram: How to config: a. Use USB-RS485 adapter connect to KC868-HA. b. download KC868-HA config tool and open it Chose your USB Serial port, baud is “9600”, parity: None…
KC868-HA let your old switch or traditional switch become support RS485 modbus protocol for KinCony’s relay controller, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch…
Hardware connection of KC868-AK ESP32 programmable keyboard: You can use 1-35 buttons for defined actions. You can use 1-36 terminal ports with extend momentary wall switch, extend cable MAX 1000…
We have developed the first DIY product for smart home enthusiasts to cultivate everyone’s interest in electronic technology. “KC101” is 4 channels universal WiFi wireless smart switch with RF 433MHz…
KC101 is 4 channels tuya universal WiFi wireless smart switch with RF 433MHz module, it’s a DIY kit for DIYer. it for your smart home system to remotely and automatically…
We have designed new version KC868-E16 V2 extend relay module. Now every relay have COM, NO, NC port and use by metal manual control switch buttons. Inside relay model :…
KC868-E16v2 relay module introduce Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO,NC Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃ Relay consumption:…
We have made arduino library for KC868-H32B Pro smart controller. it is open source and free for DIYer use. 1. Install ESP32 USB driver to your computer. download from: https://www.kincony.com/download/CH341SER.zip after installed…
We have designed KC868-E8T with Tuya module , 4G LTE module and ESP32, the 8 channel removable relay board. You can integrate KC868-E8T to home assistant by ESPHome use follow…
We have designed KC868-E8T with Tuya module , 4G LTE module (4g energy) and ESP32, the 8 channel removable relay board. You can integrate KC868-E8T to home assistant by ESPHome…
1. Hardware interface 2. How to wire 3. Ethernet setting webpage 4. How to use TUYA phone app 5. How to voice control by Amazon Alexa speaker 6. How to…
We have designed new 32 channel smart relay controller, it’s very powerful, it have 32 channel relay output, 6 digital input ports, ethernet + Tuya WiFi + ESP32 module, work…
it’s a powerful 32 channel relay controller board, have 32 channel relay output, 6 digital input ports, ethernet + Tuya WiFi + ESP32 module, work with internet or without internet.…
We have designed KC868-E16T with Tuya module and ESP32, the 16 channel removable relay board can work with ESPHome for home assistant, it also can use by Tuya mobile phone…
We have designed KC868-E16T with Tuya module and ESP32, the 8 channel removable relay board can work with ESPHome for home assistant, it also can use by Tuya mobile phone…
KC868-D16 can easily integrate to home assistant by MQTT, use for 16 channel dimmer output. Login web browser with your KC868-D16’s IP address, set ethernet work mode = MQTT, set…
Gledam KC868-E16S i ne mogu razumjeti na što me više podsjeća – cijevno pojačalo visoke klase, uređaj iz svemira cyberpunka ili artefakt iz sovjetskog steppera PBX-a. Mmožda mi se više…
I’m looking at the KC868-E16S and I can’t understand what it reminds me of anymore – a high-class vacuum tubes amplifier, a cyberpunk space device or an artifact from the…
We have designed KC868-D16 support Ethernet and WiFi work at the same time. Use Tuya phone app and home assistant in local network at the same time. It support HTTP…
KC868-D16 tuya dimmer module support Ethernet and WiFi work at the same time. Use Tuya phone app and home assistant in local network at the same time. It support HTTP…
1. Hardware interface 2. How to wire 3. Ethernet setting webpage 4. How to use manual control switch panel 5. How to use remote control 6. How to use TUYA…
Danas je na stolu kontroler Kincony KC868-A8S, nadograđena verzija prethodno razmatranog kontrolera KC868-A8. Nadograđen toliko da je zapravo već potpuno drugačiji kontroler s mnogo širim značajkama, od kojih je glavna…
The controller Kincony KC868-A8S, an upgraded version of the previously considered controller KC868-A8, is on the table today. Upgraded so much that in fact it is already a completely different…
flash_download_tool_3.9.2 ESP 32 module flash download tools
We have designed KC868-A128 ESP32 board use for huge INPUT and OUTPUT devices for home automation DIY. it is a input module based on ESP32 chip. it have 128 channel…
KC868-A128 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet RS485 module. We will supply demo code for…
Kincony se odlikuje zavidnom vještinom, razvija nove kontrolere poput Lego kockica – svaki mjesec novi model. Očito nemaju zamora. To bi nazvali: „Kontinuitet razvoja i sposobnost prepoznavanja novih trendova.“…
Kincony is distinguished by its enviable skill, developing new controllers like Lego bricks – a new model every month. They are obviously not tired. That would be called: “Continuity…
distribution board customsize design: Functions: 1. remote / locally control 4 channel AC220V 1 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger output…
distribution board customsize design: Functions: 1. remote / locally control 20 channel AC220V 1 phase power output by mobile phone and PC application. 2. use DC24v 40A DC contactor. 3.…
We have designed KC868-AI ESP32 board use for sensors for home automation DIY. it is a input module based on ESP32 chip. it have 48 channel digital input ports, every…
KC868-AI is a input module based on ESP32 chip. it have 48 channel digital input ports, every input channel use optocoupler isolation, so that can work for 1000 meter with…
KinCony ESP32 Tuya IoT adapter let relay board or IoT devices easy integrate to tuya IoT platform. We have designed by ESP32 work with Tuya module. Tuya module will connect…
home automation training -32-multi function button set by ESPHome Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home…
home automation training -31-control modbus relay by Node-Red Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home is…
home automation training -30-install Node-Red on home assistant Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home is…
home automation training -29-config manual push button for switches and LED strip Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because…
And now we’ve finally reached the pinnacle of Kincony’s technical creativity, its flagship 868-series controller, the KC868-Server. When I first saw this controller, I simply did not have words –…
home automation training -28-How to debug RS485 MODBUS curtain motor Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart…
1. as all our products are subject to selected components and factory tests, the failure rate of the machines we sell is extremely low. 2. Unlike other manufacturers, KinCony does…
home automation training -27-Notifications for Android TV in home assistant Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart…
home automation training -26-send email notifications by sensors Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home is…
home automation training -25-how to use Apple HomeKit by home assistant Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the…
home automation training -24-home assistant remote access by FREE DuckDNS
home automation training -23-any controller’s input trigger any controller’s output Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart…
WiFi DIN Rail switch module made by TUYA wifi module, use TUYA mobile phone application. support iPhone and android phone. work voltage AC110V or AC220V. You can use this wifi…
WiFi DIN Rail wifi switch module made by TUYA wifi module, use TUYA mobile phone application. support iPhone and android phone. work voltage AC110V or AC220V. You can use this…
home automation training -22-add RGBW LED strip to home assistant by ESPHome 1. chose LED strip model 2. connect with wire: VCC,DATA,GND 3. config in ESPHome: light: –…
home automation training -21-Install Raspbian OS on KC868-Server raspberry pi CM4 https://www.raspberrypi.com/software/ 1. Change KC868-Server USB boot jumper 2. Connect with USB cable with computer and KC868-Server 3.…
home automation training -20-extend digital output & input in home assistant extend output and input ports by hardware devicea. KC868-A series board (integrate to home assistant by ESPHome)…
home automation training -19-water level sensor for automation in home assistant Chose water level sensor:a. output dry contact for OPEN/CLOSE singal. b. output DC 0-5v analog voltage. 2.…
home automation training -18-ZigBee motion sensor control light in home assistant SONOFF SNZB-03 configure for home assistant by Zigbee2mqtt sensor: – platform: mqtt name: pir-state state_topic: “zigbee2mqtt/0x00124b00251e530f” value_template:…
home automation training -17-integrate USB local camera to home assistant 1. connect with your USB camera. 2. Enable home assistant “Advanced Mode”. 3. “Add-ons, Backups & Supervisor” —…
home automation training -16-integrate device to home assistant by Zigbee2MQTT Add the repository URL under Supervisor->Add-on store->…->Manage add-on repositories: https://github.com/zigbee2mqtt/hassio-zigbee2mqtt 2. Zigbee2mqtt add-on Configuration for home assistant data_path:…
home automation training -15-control IR device by Infrared extender cable ESPHome config: # Example configuration entry remote_transmitter: pin: GPIO23 carrier_duty_percent: 50% climate: – platform: mitsubishi # adjust…
home automation training -14-integrate temperature sensor to home assistant DS18B20 temperature range: -55°C to +125°C and is accurate to ±0.5°C this is the ESPHome config: # Example configuration entry dallas:…
How many relays can be installed on the controller board? Four? Eight? Kincony decided not to limit itself and equipped its KC868-A32 model of ESP32 board with as many as…
home automation training -13-integrate KC868-AG to home assistant ESPHome document: https://esphome.io/components/climate/cl…heatpumpir # Example configuration entry remote_transmitter: pin: GPIO2 carrier_duty_percent: 50% climate: – platform: mitsubishi # adjust to match your…
home automation training -12-integrate KC868-Uair to home assistant home automation training -12-integrate KC868-Uair to home assistant 1. To enable the USB 2.0 ports on the raspberry pi 4 Compute…
home automation training -11-how to use by own 433MHz RF and infrared remote Home automation training: 1. install ESP32 USB driver for KC868-Server, download from: https://www.kincony.com/download/CH341SER.zip 2. install ESP32…
home automation training courses you can learn how to add the wall switch to the home automation intelligent control system 1. home automation-switch panel type: momentary. 2.…
home automation training -9 integrate KC868-Server to home assistant by MQTT 1.MQTT communication structure diagram KC868-Server——– publish message: status of switch (status topic) Subscription message: turn on /…
home automation-training-8 Install Mosquitto broker on home assistant home automation training -8 install Mosquitto broker on home assistant 1. MQTT structure 2. Install mosquito MQTT broker on home assistant Configuration:…
We have designed KC868-A8S esp32 board, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Use SMS or call to turn ON/OFF…
KC868-A8S esp32 board based on ESP32 wifi chip, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Use SMS or call to…
home automation training -7 install home assistant mobile phone application Configuration in home assistant for home automation DIY Basic configuration default_ config: or mobile_app: discovery: It is…
home automation training -6 Configure integration of home assistant intergration in Home assistant for home automation DIY 1. All integration (components) https://www.home-assistant.io/integrations/ 2. Main functions of integration (component) Realize…
home automation training -5 Samba and file structure of HA Installation, configuration and use of Add-on Samba for home automation DIY What is Samba? software tool to realize network…
home automation training -4 Install Home Assistant OS by eMMC 1. install rpiboot.exe for Raspberry Pi Compute Module 4 eMMC USB driver. For Windows Installer For those who just want…
So, we have practiced on the initial Kincony controllers (KC868-A4, KC868-A8, KC868-Uair, KC868-AG) and now we are moving to the “big league” and will analyze the device and purpose of…
1. The demo power distribution box mainly functions: 1. 32 channel 16A output 2. 32 channel digital input for wall switch 3. 8 channel digital input for dry contact sensor…
If you want your home become smart, many people don’t know how to design and choose products. This article / video will explain what to consider and how to…
Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home is not a simple subject. It is a comprehensive…
we have designed KC868-E16S ESP32 home automation extend relay module. it’s based on ESP32 , Ethernet + RS485 + 4CH analog input + 16CH digital input ( include manual control…
We have designed KC868-A64 smart controller , so much GPIOs for user. 64 channel digital input and 64 channel digital output and 4 channel analog input, “Made For ESPHome” ,…
KC868-A64 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet RS485 module. We will supply demo code for…
I don’t know about you, but my first association when looking at the Kincony KC868-AG is a hockey puck. In fact, this is another IoT controller from Kincony based on…
We have designed KC868-A6 smart controller , many hardware resource for you to use, added LoRa and nRF24L01 wireless module interface and SSD1306 OLED and RS485 and RTC clock chip…
KC868-A6 smart controller , many hardware resource for you to use, have LoRa and nRF24L01 wireless module interface. you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet module.…
We have compiled a series of learning tutorials for esp32 based on KC868-Uair, which will be continuously published in China’s “RADIO” magazine.
In this series, we will analyze examples of the application of Kincony controllers in solving cases from practical applications. Practical cases are usually not complex, but they solve important things…
[vc_row][vc_column][vc_column_text]1.Diagram of relay Controller Download PDF details Leds status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White: network run in…
distribution board customsize design: Functions: 1. integrate raspberry pi CM4 module. 2. remote / locally control 16 +16 channel AC220V 1 phase power output by mobile phone and PC application.…
Today we will move a little away from studying of ‘serious’ controllers as the KC868 series (KC868-A4 [https://www.kincony.com/kc868-a4-hardware-design-details.html], or KC868-A8 [https://www.kincony.com/kc868-a8-hardware-design-details.html]) and let’s deal with a completely frivolous (at first…
we have designed KC868-A32 ESP32 home automation relay module. it’s new version based on KC868-A16 ESP32 relay module, add RS485 port. Support ESPHome for home assistant and Tasmota firmware for…
KC868-A32 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet RS485 module. We will supply demo code for…
wrote by Nebojsa from Croatia Using the Telegram application to communicate with the KC868-A4 provides many possibilities. For example, I chose one we have several interesting solutions that could find…
wrote by Nebojsa from Croatia Telegram Telegram is a cloud-based mobile and desktop messaging app with a focus on security and speed. The Bot API allows you to easily create programs…
We have successfully developed the most innovative product — KC868-Server. KC868-Server is a super smart controller for smart home automation and industrial automation control. KC868-Server smart controller support MOSFET output…
KC868-Server is a super smart controller for smart home automation and industrial automation control. KC868-Server smart controller support MOSFET output and wall switch connect to it directly. Also have analog…
In the last article (https://www.kincony.com/kc868-a8-hardware-design-details.html) we got acquainted with the Kincony KC868-A8 controller and its circuitry, in this article we will analyze the programming of its functional blocks (inputs, relays,…
distribution board customsize design: Functions: 1. remote / locally control 5 channel AC220V 1 phase 63A power output by mobile phone and PC application. 2. use dry contactor sensor trigger…
distribution board customsize design: Functions: 1. remote / locally control 27 channel AC220V 1 phase power output by mobile phone and PC application. 2. use “Omron” removable relay module. 3.…
While we dealt with the universal entry-level controller on ESP32 for DIY automation Kincony KC868-A4 his older brother Kincony KC868-A8 “came up” – a much more serious device with 8…
momentary wall switch introduce: LED Supply Power: DC12V S1/K1–S6/K6:key line KCOM:key Common D6–D1:LED display DCOM:LED Common Note:”Kx” with “KCOM” is dry contactor. D6–D1:LED display DCOM:LED Common Note: D6–D1: input 0V…
In the previous article (https://habr.com/en/company/ruvds/blog/647119/) of the Kincony KC868-A4 cycle, we examined the “atomic” programming of the components of this controller, in this article we will analyze more advanced examples…
We continue the ultimate guide to the Kincony KC868-A4 controller, which began in the previous article. Today we will analyze in detail the pinout of the KC868-A4 and get acquainted…
One long winter evening, I would sit in front of a monitor and browse the internet for anything interesting in general and anything interesting in particular. Unfortunately, the Internet was…
we have designed KC868-AG by ESP32 module, it’s easy to use ESPHome for home assistant. You can define RF buttons and IR buttons to control TV or air conditioner by…
we have design new KC868-E8 with 8 channel manual control buttons so that if KC868 smart controller is bad, you can also manually control relay ON/OFF.
KC868-E8 din rail relay module introduce: Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃…
KC868-A series IOT products have authorized “Made for ESPHome” from Nabu Casa. ESPHome has a great and active community that loves creating and sharing projects. “Made for ESPHome” ensures that…
AC contactor specifications coin work voltage: AC220V 1 phase power Load: AC220V MAX load current: 25A how to wire with KinCony’s smart relay controller and RC snubber:
DC contactor specifications Coin work voltage: DC12V-24V 1 phase power Load: AC220V MAX load current: 25A how to wire with KinCony’s smart controller
DC contactor specifications coin work voltage: DC24V 1 phase power Load: AC220V MAX load current: 100A how to wire with KinCony’s smart controller
DC contactor specifications coin work voltage: DC24V 3 phase power Load: AC380V MAX load current: 45A
DC contactor specifications coin work voltage: DC24V 1 phase power Load: AC220V MAX load current: 32A how to wire with KinCony’s smart controller
We have designed “KBOX” V2.0 android phone application, now “KBOX” both support use by local network or remote control by internet. The most important is you can use any MQTT…
it can work locally, without wifi connection. switch: – platform: gpio pin: GPIO2 name: “room lamp” id: lamp binary_sensor: – platform: gpio pin: GPIO36 name: “room lamp Toggle Button” on_press:…
esphome: name: kc868-a4 platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: wifi: ssid: “KinCony” password: “xxxxxxxx” captive_portal: web_server: port: 80 remote_receiver: pin: number: 23…
This is ESPHome configure for KC868-Uair smart home automation box. example for use inside temperature sensor (DS18B20) and extend temperature sensor (SHT3x) and WS2812B RGB LED strip. esphome: name:…
This is ESPHome configure for KC868-A4 smart home automation board. example for use output1-4 and input1-4 by GPIOs. esphome: name: kc868-a4 platform: ESP32 board: esp32dev # Enable logging logger: #…
This is ESPHome configure for KC868-A8 smart home automation board. example for use output1-8 and input1-8 by PCF8574 IIC chip. esphome: name: kc868-a8 platform: ESP32 board: esp32dev # Example configuration…
This is ESPHome configure for KC868-A16 smart home automation board. example for use output1-16 and input1-16 by PCF8574 IIC chip. esphome: name: kc868-a16 platform: ESP32 board: esp32dev # Example configuration…
we have designed KC868-A16 ESP32 home automation relay module. it’s new version based on KC868-A8 ESP32 relay module, add RS485 port. Support ESPHome for home assistant and Tasmota firmware for…
KC868-A16 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet RS485 module. We will supply demo code for…
we have design new KC868-E16 with 16 channel manual control buttons so that if KC868 smart controller is bad, you can also manually control relay ON/OFF. 16 channel manual control…
KC868-E16 DIN Rail Relay Module introduce: Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃…
RC absorption snubber circuit module used on protecting the relay or thyristor because it can avoid damage that from inductive electromotive force generated by the inductive load when on or…
KC868-A8 is listed by tasmota officical website support device list, here is some details how to Configuration for ESP32.
KC868-A4 is listed by tasmota officical website support device list, here is some details how to Configuration for ESP32.
momentary wall switch introduce: LED Supply Power: DC12V S1/K1–S6/K6:key line KCOM:key Common D6–D1:LED display DCOM:LED Common Note:”Kx” with “KCOM” is dry contactor. D6–D1:LED display DCOM:LED Common Note: D6–D1: input DC12V…
plastic momentary wall switch panel have 2 gang , 4 gang , 6 gang channel version. 2 gang as same appearance as 4 gang, just up and down button both…
We have designed KC868-Uair wifi temperature magic box , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet module. We will…
KC868-Uair wifi temperature magic box , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet module. We will supply demo code…
KinCony ESP32 application course is published on the udemy online course platform for everyone to learn for free. At the same time, we will publish on the online course platform…
KC868-A8 smart controller, many hardware resources for you to use, you can write any code by Arduino IDE to ESP32 wifi/Bluetooth/ethernet module. We will supply demo codes for different samples.…
KC868-A4 smart controller, many hardware resources for you to use, you can write any code by Arduino IDE to ESP32 wifi/Bluetooth module. We will supply demo codes for different samples.…
KinCony Internet of things training course will consist of two parts: theoretical principle and practical training. In the early stage, the control principle and hardware diagram for different smart solution…
This video showed how to use DS18B20 temperature for home automation. KinCony Internet of things training course will consist of two parts: theoretical principle and practical training. In the early…
KC868-A8 and KC868-A4 smart controller, many hardware resources for you to use, you can write any code by Arduino IDE to ESP32 wifi/Bluetooth/ethernet module. We will supply demo codes for…
This book we wrote in year 2021. The book takes Internet of Things technology — smart home as the main content, and develops smart home equipment through the design and…
The second verison of “teach you to DIY your own smart home system” book. This book we wrote in year 2019. Updated some information.
This book we wrote in year 2017. The first smart home automation DIY book wrote by KinCony for DIY enthusiasts.
This book we wrote in year 2017. Different application cases of MCU in the field of Internet of Things, showing common hardware schematics and source code. For university school student…
This book we wrote in year 2015. For school student to learn 8051 Microcontroller with various experiments about the hardware schematic diagram and MCU demo source code.
This book we wrote in year 2012. For school student to learn AVR mega16 Microcontroller with various experiments about the hardware schematic diagram and MCU demo source code. We have…
This book we wrote in year 2010. For school student to learn PIC Microcontroller with various experiments about the hardware schematic diagram and MCU demo source code. We have designed…
This book we wrote in year 2008. We have make the 8051 development board for school student to learn 8051 Microcontroller with various experiments about the hardware schematic diagram and…
This book we wrote in year 2010. The second version of “8051 Microcontroller and Embedbed System book”, add some information about new MCS51 extend module. For school student to learn…
This book we wrote in year 2007. For school student to learn 8051 Microcontroller with various experiments about the hardware schematic diagram and MCU demo source code. url www.hificat.com is…
IOT application and practice of smart home engineering book published in China. This book have wrote for 2 years. There are some smart home application case and IOT development resource…
distribution board customsize design: Functions: 1. remote / locally control 16 channel AC220V 1 phase power output by mobile phone and PC application. 2. use “Omron” removable relay module. 3.…
use KC868-H32 relay controller + orange pi running Node-Red work for Google home assistant voice control lamp.
Apply For Free Sample of KinCony Product 1. Available free sample product: KC868-A4 ESP32 board, KC101 Tuya electronic DIY kit KC868-A4: https://www.kincony.com/arduino-esp32-4-channel-relay-module.html KC101: https://www.kincony.com/tuya-electronic-diy-kit-kc101.html 2. Application conditions (in one of…
how to DIY home automation by home assistant guide: 1: how to install home assistant on raspberry pi4 linux system. 2. install node-red on home assistant raspberry pi4 3. make…
improvement: 1. add 8 channel dimmer control by webpage. 2. support http command for developer integrate to third-party software to change brightness and read output brightness. 3. add web config…
Now KC868-D8 can easily integrate to home assistant by MQTT, use for 8 channel dimmer output. step-A. Make sure KC868-D8’s firmware version is >= V4.34. you can download new firmware…
We have designed Smart Rack Power Strip Controller – KC868-1U-8 based on KC868-H8B smart relay controller. so the function as same as KC868-H8B. KC868-1U-8 is 8 channel relay output, use…
We have designed KC868-A8 new board update for KC868-A4. Now add ethenret RJ45 port, relay up to 8 channel and place the IIC extend port on the PCB board. You…
KC868-A8 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth/ethernet module. We will supply demo code for different…
We will produce a series of video tutorials using the IBM Node-Red DIY software
improvement: 1. add relay control by webpage 2. support http command for developer integrate to third-party software to tun on/off relay and read relay state. 3. add web config password…
We will produce a series of video tutorials using the IBM Node-Red DIY software. the Node-Red is open source. I find it’s very easy to use, almost not need write…
KC868-COLBS Logical Controller is improved on the basis of KC868-COLB: 1. add 8 channel internal relay. use jump set for “internal relay” or extend relay module. Extend relay module MAX…
KC868-COLBS Logic Controller is improved on the basis of KC868-COLB: 1. add 8 channel internal relay. use jump set for “internal relay” or extend relay module. Extend relay module MAX…
We will produce a series of video tutorials using the IBM Node-Red DIY software. the Node-Red is open source.I find it’s very easy to use,almost not need write many program…
distribution board customsize design: Functions: 1. remote / locally control 32 channel AC220V 1 phase power output by mobile phone and PC application. 2. use “Omron” removable relay module. 3.…
We developed KinCony smart controller IP scan tool for easy to find out controller’s IP address, this tool use for “B” or “BS” series controller. It will scan all KinCony…
distribution board customsize design: Functions: 1. remote / locally control 5 channel DC24V valve and one 3 phase pump (motor) by mobile phone and PC application. There are 5 switch…
We have designed new smart controller KC868-H32BS. it have 6 digital input ports for sensors, 34 digital input ports for self-reset switch button and 32 P-MOSFET output ports, support use…
We improved ethernet wifi relay module — KC868-H32BS ethernet relay for smart home automation DIY. Now KC868-H32BS smart controller support MOSFET output and wall switch connect to it directly. it’s…
distribution board customsize design: Functions: 1. remote / locally control 16 channel AC220V 1 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger output…
distribution board customsize design: Functions: 1. incoming power AC380V 3 phase. 2. remote / locally control 6 channel AC220V 1 phase power and 3 channel AC380V 3 phase output by…
distribution board customsize design: Functions: 1. remote / locally control 1 channel AC380V 3 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger output…
distribution board customsize design: Functions: 1. remote / locally control 16 channel AC220V 1 phase power output by mobile phone and PC application. 2. every channel output by AC contactor…
distribution board customsize design: Functions: 1. incoming power AC380V 3 phase. 2. remote / locally control 23 channel AC220V 1 phase power and 4 channel AC380V 3 phase output by…
distribution board customsize design: Functions: 1. remote / locally control 32 channel AC220V 1 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger output…
distribution board customsize design: Functions: 1. incoming power AC220V 1 phase. 2. remote / locally control 8 channel AC220V 1 phase power output by mobile phone and PC application. 3.…
distribution board customsize design: Functions: 1. incoming power AC380V 3 phase. 2. remote / locally control 23 channel AC220V 1 phase power and 3 channel AC380V 3 phase output by…
distribution board customsize design: Functions: 1. remote / locally control 16 channel AC220V 1 phase power output by mobile phone and PC application. 2. every channel output AC220V 45A 3.…
distribution board customsize design: Functions: 1. remote / locally control 16 channel AC220V 1 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger…
distribution board customsize design: Functions: 1. remote / locally control 8 channel AC220V 1 phase power output by mobile phone and PC application. 2. use dry contactor sensor trigger output…
We have designed Mini version for KC868-COLB. it have 8 digital input ports and 8 analog input ports, all functions as same as KC868-COLB. KC868-COLB-Mini is smaller than KC868-COLB, it…
KC868-COLB Mini Logic Controller : 1.both have Ethernet and Wifi work at the same time 2.work in local network and send data to your own cloud server 3.Ultra long distance…
KC868-H32B integrate into Loxone home automation system guide have uploaded on YouTube channel. You can turn ON/OFF relay and update relay state by Loxone MiniServer. It work as Loxone extension…
Lesson4- How to use Arduino to read DS18B20 temperature sensor
Lesson3- How to use Arduino to control relay by wall switch button
Lesson2 – How to use Arduino to control relay ON/OFF
We bring you the remote experience IoT products service. Now you can remote control KC868 smart controller and monitor real time video screen by KinCony’s YouTube channel live streaming. This…
KC868-A4 smart controller , many hardware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth module. We will supply demo code for different…
KC868-A4 smart controller , many hareware resource for you to use, you can write any code by Arduino IDE to ESP32 wifi/bluetooth module. We will supply demo code for different…
improvement: 1. Support MQTT by ethernet. 2. Fixed bug that can’t use 2pcs KC868-H32B by WiFI MQTT at the same time. Now no limit, multi controller can be used at…
improvement: 1. KC868-COLB default set “enable” for auto upload function, before version default is “disable”. 2. Fixed problem that if have a DS18B20 temperature value auto loaded, other temperature sensors…
Now KC868-COLB MQTT input module can easily integrate to home assistant by MQTT, use for 16 channel digital input + 16 channel analog input + 5 channel DS18B20 temperature sensor.…
MulitiBoardCtrl tool is windows software for PC and tablet. it support use KC868 all relay controller model and all KC868-COL/COLB logical controller. 1. one software window support MAX 254 device…
improvement: 1. add read input state http command for developer integrate to third-party software. you can send http command to get information of 6 channel digital input port state. Command…
Now KC868-H32B can easily integrate to home assistant by MQTT, use for 32 channel relay output and 6 channel digital input port. A. make sure KC868-H32B’s firmware version is >…
The power outlet products, with the same style as switch panel products, are used together with switch. You can DIY smart home automation by different color style as you like.…
power outlet can change different color style frame. You can chose different color frame. after you order , please leave message what color you want. If you not leave message,…
firstly thanks to vmarandola , he have writen the arduino code for KinCony’s voice module (based on ESP8266 wifi module). here is his github link for source code: https://github.com/vmarandola/KinconyAlexaGoogle if you have voice…
KC868-H32B relay controller support http webpage control. It can control by http command for software engineer. firmware V4.0.1 improvement: 1. add relay control by webpage 2. support http command for…
[vc_row][vc_column][vc_column_text]1.Diagram Led status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White: network run in “TCP Client” mode. Yellow: network run…
This is video demo tour make from Czech Republic: Why need you make smart home demo video then become distributor? Order KinCony’s mainly IoT smart home automation products in our…
Here is the Ultimate Smart Home Tour for 16 Channel Smart Power Distribution Board DIY mainly used by KC868-H16B Smart Relay Controller and KC868-COLB logical controller and power meters. Step…
KC868-COLB Logical Controller main improvements than KC868-COL: 1.both have Ethernet and Wifi work at the same time 2.work in local network and send data to your own cloud server 3.Ultra…
KC868-COLB Logic Controller main improvements than KC868-COL: 1.both have Ethernet and Wifi work at the same time 2.work in local network and send data to your own cloud server 3.Ultra…
how to config wifi ssid and password of KC868-H32B smart home automation controller by website. (Need KC868-HxB smart controller fimware version more than V3.0 ) Here is Smart Home…
How to use KC868-D8 dimmer and KC868-H32B relay controller board control RGB LED strip by wireless remoter or wall switch panel or mobile phone application or ethernet / RS485…
how to use momentary latch switch or push button control relay output by KC868-COL logical controller and KC868-Hx relay controller for smart home automation DIY. KC868-HxB smart relay controller…
KC868-COL more details: https://www.kincony.com/programmable-logic-controller.html 1. KC868-COL cooperates with KC868-Hx relay controller to work as automatic control system. KC868-COL is the AI brain and KC868-Hx is actuator. KC868-COL use IFTTT…
Make your old light switches smart by KC868-COL logical controller and KC868-Hx relay controller for smart home automation DIY. KC868-HxB smart relay controller both include ethernet port and wifi.…
How to use KBOX-Pad application for windows PC and Win10 tablet control KC868-H32B ethernet wifi relay module and monitor for KC868-COL logical controller with digital , analog input ,…
How to use KBOX-Pad application remote by teamviewer for windows PC and Win10 tablet control KC868-H32B ethernet wifi relay module and monitor for KC868-COL logical controller with digital ,…
Build Your Own Smart System Products with same function as official application.We supply change app ico OEM service. Change application ICO , name , start page or menu language.
KBOX-Pad windows 10 tablet use for KC868-H32B ethernet wifi relay module and monitor data for KC868-COL logical controller with digital , analog input , temperature sensor value. All ico and…
We have write plugin file for domoticz. You just need 4 steps integrate KC868 relay controller into domoticz smart home platform. It’s very easy. 1. Make sure you have a…
[vc_row][vc_column][vc_column_text] 1. What switch panel or buttons can be used? KC868-D8 input ports (K1+ — K8+) and (K1- — K8-) support dry contact signal. You can use any dry contact…
We improved ethernet wifi relay module — KC868-H2B ethernet relay for smart home automation DIY. 1: Both have ethernet port and WiFi port. 2: Ethernet and WiFi work at the…
We improved ethernet relay module — KC868-H4B for smart home automation DIY. 1: Both have ethernet port and WiFi port. 2: Ethernet and WiFi work at the same time,you can…
We improved ethernet wifi relay module — KC868-H8B for smart home automation DIY. 1: Both have ethernet port and WiFi port. 2: Ethernet and WiFi work at the same time,you…
We improved ethernet relay module — KC868-H8B for smart home automation DIY. 1: Both have ethernet port and WiFi port. 2: Ethernet and WiFi work at the same time,you can…
We improved ethernet relay module — KC868-H16B for smart home automation DIY. 1: Both have ethernet port and WiFi port. 2: Ethernet and WiFi work at the same time,you can…
1. We have update KBOX android phone application for KC868-D8 smart dimmer controller. Now you can change brightness for LED strips and lamps or fan or control speed for motor…
We have create smart home automation DIY forum: https://www.kincony.com/forum/ If you have any questions, you can post your questions on our forum, every day our administrator will reply your questions…
We supply components for different DIY smart distribution board bundle. How to DIY , you can see details on our YouTube channel videos.
How to set network configuration for UDP, TCP Server, and TCP Client of KC868-HxB ethernet and wifi smart controller. Subscribe to KinCony IOT for weekly tech amusing DIY videos…
How to update MCU firmware by USB-RS232 cable for KC868 Smart Controller. Subscribe to KinCony IOT for weekly tech amusing DIY videos hosted by XuWei! We will continue to develop…
Many people always give us house diagram phto and want to build a smart house. Now I write the article tell you how to plan. 1. What function do you…
How to use the “KBOX smart home” app of the KC868-H32B smart home automation controller. it controls relay output without the internet. it controls relay output without the internet.…
How to use”KinCony smart home” app of the KC868-H32B smart home automation controller. It needs internet and cloud servers for remote control. Here is Smart Home Tech Tour for…
How to config wifi SSID and password of the KC868-H32B smart home automation controller. Here is Smart Home Tech Tour for KinCony’s KC868-H32B IOT module DIY. Step by step,…
Hardware introduction of KC868-H32B smart home automation controller. Here is Smart Home Tech Tour for KinCony’s KC868-H32B IOT module DIY. Step by step, it’s very easy to DIY. Perfect…
Raspberry Pi 4 Model B is the latest product in the popular Raspberry Pi range of computers. It offers ground-breaking increases in processor speed, multimedia performance, memory, and connectivity compared…
KinCony offers Home Automation solutions. 32 channel Relay controller is popularly used now. Home devices can be controlled over the Internet or on the Local Area Network without the…
Send temperature and humidity data from the DHT11 DS18B20 sensor to Server by Ethernet or wifi Network. Users can see the current temperature and humidity data via mobile phone…
how to add KinCony’s ip camera to “KinCony smart home” phone app.
Here is the Smart Home Tech Tour for 32 channel wifi relay controller of KC868-H32LW. use mobile phone turn ON/OFF 32 relays. Step by step tell you: how to…
How to use 8-2 channel relay board PC software in LAN for local control. Software download from: https://www.kincony.com/document
How to use 8-2 channel relay board PC software in WAN for remote control. Software download from: https://www.kincony.com/document
How to use 32-16 channel relay board PC software in LAN for local control.it does not need the internet. Software download from: https://www.kincony.com/document
Firstly,make sure you have installed Node-Red on home assistant.Now let’s begin to add our KC868 relay controller to home assistant for turn ON/OFF every relay. Goto “Configuration” — “Helpers”…
About Node-Red Flow-based programming for the Internet of Things. Node-RED is a programming tool for wiring together hardware devices, APIs and online services in new and interesting ways. It…
Install Home Assistant on Raspberry Pi 4 This guide will help you get Home Assistant running on a Raspberry Pi, turning your Raspberry Pi into the ultimate home automation…
How to use 32-16 channel relays board PC software in WAN for remote control. Software download from: https://www.kincony.com/document
How to use KBOX smart home automation phone APP control KC868-Hx relay board in LAN(no need internet) App download from : https://www.kincony.com/document
Here is the Ultimate Smart Home Tech Tour for KinCony’s IoT module DIY. Step by step, it’s very easy to DIY. Perfect for Smart home 2020. 1. Different wireless…
Here is the Ultimate Smart Home Tech Tour for Smart Home Automation Project DIY used by KinCony’s KC868 Smart Controller. It’s very easy to DIY. Perfect for Smart home…
Here is the Smart Home Automation DIY Project use by KinCony’s KC868 smart network relay module and self-reset switch button. It’s very easy to DIY. Perfect for Smart home…
This video circuit diagram of the Smart Power Distribution Box is based on video link: https://youtu.be/URHqefy8FzM This is 3 units 3 phase + 23 units single phase DB. According…
This video tells you how to read power meter voltage current frequency by RS485, send data to KC868-COL, read all data on PC software.
1. KC868-COL cooperates with the KC868-Hx relay controller to work as an automatic control system. KC868-COL is the AI brain and KC868-Hx is the actuator. KC868-COL uses the IFTTT…
[vc_row][vc_column][vc_column_text]1.Diagram of relay Controller A.KC868-H32BS B.KC868-H32B C.KC868-H16B D.KC868-H8B E.KC868-H4B F.KC868-H2B Led status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White:…
We improved ethernet wifi relay module — KC868-H32B for smart home automation DIY. The new model called “KC868-H32B”. What’s the difference between “KC868-H32B” and “KC868-H32L”? 1: Both have ethernet port…
We improved ethernet relay module — KC868-H32B for smart home automation DIY. The new model called “KC868-H32B”. What’s the difference between “KC868-H32B” and “KC868-H32L”? 1: Both have ethernet port and…
Gsm alarm for home automation DIY, use logical program for more reliable send alarm gsm SMS and telephone call.
This video show you explains the working principle of the water level sensor and the difference between the floating switch sensor and the water level sensor. How to use…
KC868-COL cooperates with the KC868-Hx relay controller to work as an automatic control system. KC868-COL is the AI brain and KC868-Hx is the actuator. KC868-COL uses the IFTTT command…
1. KC868-COL cooperates with the KC868-Hx relay controller to work as an automatic control system. KC868-COL is the AI brain and KC868-Hx is the actuator. KC868-COL uses IFTTT command…
We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost no need to…
Here is the Smart Home Tech Tour for 32 channel network ethernet relay controller of KC868-H32L. use mobile phone turn ON/OFF 32 relays. Step by step tell you: how…
This video shows how to use the Arduino program to control 32 channel(KC868-H32L) ethernet relay module by serial communication. Here is the Ultimate Smart Home Tech Tour for KinCony’s…
We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost not need to…
We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open source.I find it’s very easy to use,almost not need write many…
We will produce a series of video tutorials using the IBM Node-Red DIY software.The Node-Red is open source.I find it’s very easy to use,almost not need write many program…
“KinCony Smart Home APP” android phone app updated, we have added new functions: 1. Add login window supports multiple account switching and adds the function of remembering password. 2. Fixed…
We have make firmware update tool for KC868-Hx smart relay controller and KC868-COL Programmable Logic Controller (analog input digital input module). If the product serial number like “HxxBxxxxxxxxxxxx” , include…
KC868-COL acquisition board (analog input digital input module) is used to read AI, DI, Temperature,electricity meter . The equipment supports 5 channel of DS18b20 temperature sensors, 16 channel of Digital…
We have updated new firmware of KC868-COL and new PC software. update function as follows: Support 8 power meter monitor for Power consumption,voltage, current, frequency, power factor, active power value.…
We have updated new PCB for voice module (for Alexa and Google home speaker). Add a switch button for software config setting and module running. Before when you download data…
“KBOX” iOS phone app updated, we have added new function: 1. update add controller scene mode, support add KC868-H2/H4/H8/H16/H32 you can add any controller’s any relay switch output to scene…
We have designed the KC868-D8 for 8 channel smart dimmer. It can control by wall switch button, wireless remoter, also work with ethernet or RS485 port, open protocol for development…
KC868-D8 smart dimmer controller support HTTP, MQTT for home assistant. Solution A: KC868-D8 dimmer controller work with DC12V or DC24V LED strip by Power Driver Solution B: KC868-D8 dimmer controller…
“KBOX” iOS phone app updated, we have added new function: 1. update add controller mode, support add KC868-H2/H4/H8/H16/H32 2. add “TOUCH” mode for every relay switch output that can auto…
[vc_row][vc_column][vc_column_text] How to connect wire with lamp. How to connect wire with curtain or garage or shutter motor. How to connect wire with SSR ( Solid State Relay) to extend…
[vc_row][vc_column][vc_column_text]1.Diagram 2.How to use software Firstly, use VirCom tool on PC to find KC868-COL’s IP and Port. Note: in VirCom [Work Mode]=[TCP Server] Input IP and Port Connect/disconnect— PC Connect/disconnect with KC868-COL.…
[vc_row][vc_column][vc_column_text]1.Diagram of relay Controller A.KC868-H32/H32W B.KC868-H16/H16W C.KC868-H8/H8W D.KC868-H4/H4W E.KC868-H2/H2W 2.Network Setting A.WiFi config (if you use ethernet version, skip WiFi config step): B.Set Work Mode for remote control (Need internet…
[vc_row][vc_column][vc_column_text] google home voice module can connect with relay controller directly or by one RS232 cable to extend distance. Click below photo to see video how to use [/vc_column_text][/vc_column][/vc_row]
[vc_row][vc_column][vc_column_text] alexa voice module can connect with relay controller directly or by one RS232 cable to extend distance. Click below photo to see video how to use [/vc_column_text][/vc_column][/vc_row]
[vc_row][vc_column][vc_column_text]1.Diagram K1–K6:key line KC:key Common D6–D1:LED display (LED Supply Power: DC12V) DC:LED Common K1….K32,ALL ON, ALL OFF line connect with dry contactor button. every button need 1 line, another is…
Now we have development new firmware and PC software for KC868-COL for powerful logical control function. Before KC868-COL only can read data, now you can create any IFTTT command for…
Welcome to KinCony family! We are focus on the R & D and production of intelligent and automatic IOT products, providing kinds of products for home automation ,industrial and agricultural.…
“KBOX” android phone app updated, we have added new function: support use domain for controller’s IP address,support use DDNS. you can see input port status of sensors on homepage. Sort…
KControl is an United States electric brand, the owner of this US trademark is Hangzhou Kincony Electronics Co., Ltd. founded in 2007, which is an innovative enterprise focus on the…
2 channel Smart Power Distribution Box control by phone APP and PC computer software. It can work in LAN or WAN, not need internet also can use. This is demo…
4 channel Smart Power Distribution Box control by phone APP and PC computer software. It can work in LAN or WAN, not need internet also can use. This is demo…
8 channel Smart Power Distribution Box control by phone APP and PC computer software. It can work in LAN or WAN, not need internet also can use. YouTube video tour:…
We provide kinds of samrt distribution box, the difference is the number of channels and load power circuit current. This is demo video that how to diy a Smart Power Distribution…
Smart Home android phone LAN version app “KBOX” updated, we have added new function: add scene mode. you can control many KC868-Hx smart controller’s relay output at the same time.…
Now , All Smart Controller (KC868-H2,KC868-H4,KC868-H8,KC868-H16,KC868-H32) have new firmware, and have new function followings: 1:The function of power-off memory of relay switch is added. If the power is cut off…
This video show you how to control 32 channel relays output by home assistant, such as control by Apple homekit,voice control by iPhone or iPad’s Siri, control by website.…
This video show you how to control 32 channel relays output for many ways, such as control by switch panel for 300 meter long distance,by wireless remoter control 32…
Here is the Most powerful function of Smart Home Automation Model Project used by KinCony’s KC868 Smart Controller. Demonstration function of Smart Building model: 1. Individual control of light…
In order to improve the work distance between the switch and the manual control board, and to increase the 32 channel relay output wireless remoter control function, we developed the…
Button switch module connect with KC868-Hx smart controller by RS232 port, wall switch panel or any buttons can connect with this board for manual control relay switch. It can use…
We have write a program for TCP/IP Socket -> MQTT protocl convert help smart home DIYer to use home assistant for automatic control. So now all KC868-Hx smart controller can…
ethernet or wifi relay module controller work in local LAN network by android app , not need cloud server and internet. just mobile phone , KC868-Hx smart controller connect…
Here is the Smart Home Tech Tour for 32 channel wifi relay controller of KC868-H32W. use mobile phone turn ON/OFF 32 relays. Step by step tell you : how…
For some dealers and customers who want to build their own cloud server by using KinCony’s IOT smart home products, we have summarized three ways to build their own smart…
Before decorating the house, how to design and calculate how many circuit breakers are needed for intelligent control distribution? In theory , the more circuit breakers there are, the…
This tutorial is a step-by-step guide that shows how to build a standalone ESP8266 Web Server that controls KC868-Hx Controller’s relays. This ESP8266 NodeMCU Web Server is mobile responsive and…
We have written a new development and debug software tool for KC868-Hx smart relay controller. There are two test versions available: 1.TCP Server Version tool: Debugger download: KC868Hx-Debug-Server (use in…
We have add the new icos for many electrical equipment. You can download the package and put all to your KC868 Smart Controller PC software install directory, then setting in…
KC868 Smart Home Automation Module FAQ: 1. Can multiple controller be used in the same mobile app? Yes, multiple controllers of different models can be added to a mobile account.…
We improved ethernet relay module — KC868-H32. The new model called “KC868-H32L”. What’s the difference between “KC868-H32” and “KC868-H32L”? 1: Relay Max load from 5A to 10A. 2:Use pluggable terminals,easy…
KBOX android mobile phone app for KC868-Hx Smart Controller V1.0 released. It support control relay in LAN, not need internet. Just add all KC868-Hx controller to a mobile phone by…
This 32 key wall switch panel support control KC868 smart controller’s 32 relay on one switch panel . This switch panel connect with manual control board.
This 16 key wall switch panel support control KC868 smart controller’s 16 relay on one switch panel . This switch panel connect with manual control board.
This 8 key wall switch panel support control KC868 smart controller’s 8 relay on one switch panel . This switch panel connect with manual control board.
Joint construction of “technology research” base by KinCony and Hangzhou Normal University Invited by the electronic information department of Hangzhou Normal University, KinCony team held a speech on “Application of…
2 channel RS232 COM serial port extension, connect to manual control board or Google or Alexa voice module with KC868 smart controller at the same time.
remote see the current temperature and humidity value.wifi network.see history of last week or last day or last hour value.The upper limit and lower limit value of temperature or humidity…
remote see the current temperature and humidity value.see history of last week or last day or last hour value.The upper limit and lower limit value of temperature or humidity can…
fish feeder automatic remote control by phone DIY based on Smart Home Tech used by KC868-H2W Smart Controller.
Output Load:each 250V/10A Communication mode:WiFi/RS232 Output port qty:2 ports
Products Parameter: Dimension: 108x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/10A Communication mode:WiFi/RS232 Input port qty:4 ports Output port…
Here is the Ultimate Smart Home Tech Tour for Distribution Board DIY used by KC868 Smart Controller. Step by step, it’s very easy to DIY. Perfect for Smart home 2020.…
how to use zigbee PIR sensor with KC868-G zigbee gateway to send alarm message to mobile phone.
how to use IR function inside of KC868-G smart home hub, it can control TV,DVD,Air conditioner and any IR signal household electrical appliances.
AC220V Power 2 channel power distribution box remote control by phone app or PC computer software or manual control or Google home / Amazon Alexa echo speaker voice control relay.…
KC868-COL acquisition board is used to read AI, DI, Temperature,electricity meter . The equipment supports 5 channel of DS18b20 temperature sensors, 16 channel of Digital input signal detection, 16 channel…
how to add ZigBee IR adapter to KC868-G smart home hub, it can control TV,DVD,Air conditioner and any IR signal household electrical appliances.
how to add ZigBee light dimmer switch pancel to KC868-G smart home hub, it can control device by phone app for send zigbee , RF315MHz,RF433MHz, IR signal.
how to add ZigBee light switch pancel to KC868-G smart home hub, it can control device by phone app for send zigbee , RF315MHz,RF433MHz, IR signal.
how to set wifi ssid and password of KC868-G smart home hub, it can control device by phone app for send zigbee , RF315MHz,RF433MHz, IR signal. ?
every KC868 smart controller only can add to one phone app account, if you need to add to another app account, you must delete the controller in your app account…
every KC868 controller can only add to one phone app account, if some body want to control one controller. the master account can authorize sub-account to share equipment control. ?
how to create scenes for relay ON or OFF. Such as all relay ON, all relay OFF, or relay1 ON, relay2 OFF, relay 3 ON by one button on phone…
How to set timer with scene: such as 8:00 AM to do scene (ALL relay OFF), or 06:00 PM to do scene (ALL relay ON). You can set scene run…
16 Channel Digital input,16 Channel Analog input,5 Channel Temperature,99 Channel Power Meter.
32 channel power box control by phone APP and computer software or voice control by Google home or Amazon alexa speaker.
Products Parameter: Dimension: 108x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/10A Communication mode:Ethernet/RS232 Input port qty:8 ports…
A case of mobile app control and voice control solution for oxygen pump in fish tank by using network relay controller. At the same time, water temperature in fish tank…
Today, we are going to introduce you to control the computer remotely anytime and anywhere. Sometimes we want to find some information or data on the computer in the office,…
KinCony publishing and distributing dozens of books and magazines related to MCU technology, electronic technology and Internet of Things technology, which are regarded as teaching books of IOT technology by…
Here are some successful cases of KinCony’s smart controller use in different fields. Case 1 is our Client use KC868-H32 to remote or auto control on farm in Korea. Case…
XuWei: Founder & CEO of KinCony Electronics Co., Ltd. Major in Computer Science and Technology , Zhejiang University. Young Technological Innovator in HangZhou in 2015. Special Teacher…
All the controller products of our company, we all open the interface of the communication protocol free of charge, and provide R & D technical supports, so that you can…
OEM service mainly makes LOGO replacement for existing products and software content. We can Custom Smart Controller and Smart Power Distribution Box. For customization of features and interfaces, we will…
Because the intelligent control system is difficult to develop, long development cycle and frequent maintenance & updating, many dealer customers choose the OEM service, which can bring their products into…
Output Load:each 250V/10A Communication mode:Ethernet/RS232 Output port qty:2 ports
Output Load:each 250V/10A Communication mode:Ethernet/RS232 Input port qty:4 ports Output port qty:4 ports
1.Registered Account for https://sinric.com 2.Connect KinCony voice control module with PC by USB. 3.Install USB-COM driver. 4.Config voice module’s SSID and password of wireless router, sinric API KEY. 5.Conect…
It can local or remote control motor pump by phone APP or PC software in LAN or WAN. If you have ipcamera, you can see the video on your PC…
use this wireless gateway development tool, you can control KinCony’s wireless gateway KC868-S and KC868-G ZigBee and RF(315MHz, 433MHz) device by your code. Such as control light, curtain, dimmer.…
Amazon Alexa or Google Home Voice Control Assistant
Use KC868-H8 / KC868-H32 controller to remote control relay while watch ipcameras. It support 1-4 CCTV.
Use KC868-H8 / KC868-H32 Smart Controller to remote control relay while watch ipcameras.
Model size of smart home building: 60cmx60cmx50cm(LxWxH) Demonstration function of Smart Building model: 1. Individual control of light in each room 2. Electric Garage Door Control 3. Electric curtain control…
You can use amazon Echo Plus control socket directly. Our plug is standard ZigBee3.0 protocol. Also can used by philips hue hub. The control demo can see our video link: https://www.kincony.com/zigbee-3-0-smart-plug-voice-control-by-echo-plus.html…
You can use amazon Echo Plus voice control socket directly. Our plug is standard ZigBee3.0 protocol. Also can used by philips hue hub.
program code by yourself that can control ZigBee device , such as light, dimmer, curtain, IR by socket port, the gateway not need internet.
Why KC868 is a super controller? It can: Control by phone APP (iOS & Android) PC remote(WAN-internet) or local(LAN-no internet) control Voice Control by Amazon Alexa & APP (Need…
KC868-Hx Local Control by PC software via USB-RS232. First install the USB-RS232 adapter driver. Then search the COM number, set in the software.
Firstly, config the WiFi work mode in “UPD” that in WAN, then change to “TCP Server” that in LAN. Note: After changing the parameters, the power should be restarted.
How to config wifi with KC868-H8W KC868-H32W smart home ip relay controller
Temperature protector fixed by different temperature value. Contact : NO(Normal Open) Temperature : 15°C~150°C Rated Power : 250V 5A Lead Wire Length : 7.3cm / 2.9″ Head Dimension : 20…
Water Level Float Switch introduce: Specifications: Cable length : 2M Cable material :PVC Cable sq : 0.5sq mm Micro switch : silver Cable diameter : 8mm Micro switch: 10(8)A 220V…
Manual Control Keyboard is mainly used to control the device of KC868-H8 and KC868-H32 by hand. And it’s connected through the cross serial port cable between the board and the…
video demonstration for 8 or 32 relays control by keyboard or hand or wireless remoter or touch panel.
How does mobile app for water level alarm function demonstration.
Rapid Development of Smart Home system– Rapid Development of Smart Home system _ DIY Intelligent Remote Controlling Power Distribution Box By Xu Wei After reading the article of the…
The 4K HD video introduces the whole process of a PCB board being SMT & DIP components welded become a smart home control board. How to test the quality…
power failure sensor introduce: A. Product characteristics: The power-off sensor will output N/O and N/C switching value signal, when any phase is power off from the phase A, phase B…
power failure APP alarm function demonstration. Connect the sensor to kc868-h8 controller via wires to trigger alarm demonstration.
Today, we will expose the whole process of the PCB circuit board production; let us together enter into the production workshop of Hangzhou KinCony Electronics, to see how the circuit…
We will start to analyze KC868-Hx or KC868-HxB communication protocol. The KC868-H2B,KC868-H4B,KC868-H8B,KC868-H16B,KC868-H32B just different channel relays. The protocol is almost same. If you use KC868-HxB series relay controller, when the…
KinCony wall touch dimmer of ZigBee wireless smart home solution of KC868 smart home system Video demonstrates ZigBee dimmer manual control, app control.
KinCony wall touch switch of ZigBee wireless smart home solution of KC868 smart home system Video demonstrates ZigBee switch manual control, app control, dual switch panel control of one…
How to configure mobile app and alarm function demonstration. Connect the sensor to kc868-h8 controller via wires to trigger alarm demonstration.
Home security Pir Sensor Alarm Detector work with KC868 controller. How to configure mobile app and alarm function demonstration. Connect the sensor to kc868-h8 controller via wires to trigger…
Uair temperature and humidity development board shell install. There are interface of temperature sensor, humidity sensor and PM2.5 sensor on the PCB board (PM2.5 sensor is not standard, pls…
The development board of air quality detection module (U-air hardware PCB) can upload the data collected by the sensors of temperature, humidity and PM2.5 to the server via GRPS. Clients…
Smoke Detector Sensor Product parameters: Operating voltage: 12v/DC~24v/DC Static current: ≤ 2MA Alarm current: ≤ 10MA Operating temperature: -10 ℃ ~ 50 ℃ Operating humidity: ≤ 95%RH Alarm mode: Networked output…
PIR Sensor Product Parameter Sensor Type: Imported high sensitive sensor Operating Voltage: 9v/DC~24v/DC Product Category: Wired wide Angle Installation: Wall hanging or Angle installation Detection Angle: 110 ° Operating temperature:-10…
Magnetic door sensor Product Parameters” Dimension:106*38*10mm 106*16*16mm 106*50*50mm Induction Distance: 50-70mm Switch Form:N/C, N/O and Converted Electrical Parameter: Max power 10W, Max Voltage 100V, Max Current 0.5A Material: Zinc Alloy, silver gray…
Gas detector sensor product parameter: Sensor: New nanometer technology sensor, long service life Induced Gas: Coal gas, natural gas, liquefied petroleum gas Alarm concentration: Coal gas 0.1~0.5%、natural gas 0.1~0.3%、liquefied petroleum gas…
Water leak sensor product parameters: Operating voltage: 12v/DC Operating temperature: 0 ℃ ~ 50 ℃ Output form: Relay N/C, N/O optional Static power consumption: < 0.3w Alarm power consumption: ≤ 0.5w Operating…
This is KC868-H8 Controller & KC868-H32 Controller local control demo source code by LAN mode use Visual Studio VB2017 . It can control devices by App account. The Demo code…
This is KC868-H8 Controller & KC868-H32 Controller local control demo source code by LAN mode use python by PyCharm tool. It can control relays by IP address and Socket port.…
This is KC868-H8 Controller & KC868-H32 Controller local control demo source code by LAN mode use Xcode 10.x. It can control relays by IP address and Socket port. The Controller…
This is KC868-H8 Controller & KC868-H32 Controller local control demo source code by LAN mode use Android Studio. It can control relays by IP address and Socket port. The Controller…
This is KC868-H8 Controller & KC868-H32 Controller local control demo source code by LAN mode use Visual Basic 2005. It can control relays by IP address and Socket port. The…
Intelligent power distribution box is composed of traditional leakage protector, air switch, AC contactor and KC868-H8. Compared with the traditional power distribution box, it is safer to cut off the strong power…
Security and intelligent linkage control solution are mainly composed of sensors and application equipments. Through the trigger of the sensor, the alarm message can be sent to the user’s mobile…
At present, the traditional door lock is being replaced by electronic access control system. There are magnet snap-in controls for office, and password & fingerprint locks for homes or hotels,…
The network camera currently has a very wide application in the field of security. But the quality is different for some major brands in the market. Because the camera is…
At current market, the Wi-Fi socket has been popular, but some of them have low load capacity, the Wi-Fi signal is easy to be disturbed and other unstable factors, which…
For a user who is hosting a server, it is a very bad thing if the server has a crash. Because we have to get someone to find the server…
Intelligent irrigation remote controlling system consists of automatic controlling technology, communication technology, computer technology and so on. The system is mainly designed for daily irrigation control and management in fields…
Power Distribution Box can control all kinds of electrical equipment and connect sensors to realize the function of security system. The video will show you step by step…
There two steps for using the device of KC868-H8 or KC868-H32: Firstly: to configure Wi-Fi and get the device into the internet via Wi-Fi Secondly: Scan the QR code; add…
This manual is for the controlling when you have the account for Kincony Smart Home System; For how to get the account, please see the detail 《2-KC868-H8&H32 APP User Manual》!…
First Step: Please power the device KC868-H32 and connect it into the internet. Second Step: Download the program from: http://www.kincony.com/download-readme Please release the control program on the root directory…
Please kindly note there are two controlling mode: Local Controlling and Remote Controlling. When the device and your computer are connecting to the Ethernet, (same local internet), following the manual…
Relay Controlling(SET): RELAY-SET-x(1bytepack_num),x(1byterelayserialnumber),x(1byteaction0/1) RETURN: RELAY-SET-x(1bytepack_num),x(1byterelayserialnumber),x(1byteaction0/1),OK/ERROR Relay Status(READ): RELAY-READ-x(1bytepack_num),x(1byterelayserialnumber) RETURN: RELAY-READ-x(1bytepack_num),x(1byterelayserialnumber),x(1bytestatus0/1),OK/ERROR Input Status(GET_INPUT): RELAY-GET_INPUT-x(1bytepack_num) RETURN: RELAY-GET_INPUT-x(1bytepack_num),x(1bytestatus),OK/ERROR Trigger Alarm(ALARM): RELAY-ALARM-x(1bytealarmchannel) BACKSTAGE RETURN: RELAY-ALARM-x(1bytealarmchannel),OK/ERROR Re: Without receiving the RETURN, ALARM…
Products Parameter: Dimension: 272x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/3A Communication mode:Ethernet/RS232 Input port qty:6 ports Output…
Products Parameter: Dimension: 148x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/10A Communication mode:Ethernet/RS232 Input port qty:8 ports Output…
irstly, pls have a check if it’s TCP mode by the “Vircom” Program(as below) After making sure it is already the TCP mode, then open the “Relay” program Input IP…
KC868-H8&H32 APP user manual Firstly, pls have a check if it’s the UDP mode by the “vircom” program: Then, please scan the below QR code to download the APP. For…
Open the Vircom program as below, click the Device Icon As default, when the device had been connecting to the internet, it shows the device automatically. If not showing,Pls click…
The following table lists the functional parameters of the KinCony Smart Home Host (wireless and wired versions). You can choose the right product by comparing parameters.
Output Load:each 250V/5A Communication mode:WiFi/RS232 Input port qty:6 ports Output port qty:32 ports
Output Load:each 250V/10A Communication mode:Ethernet/RS232 Input port qty:8 ports Output port qty:8 ports
kc868-h32 ethernet network relay control Building model by PC
kc868-h8 relay control Building model by APP
Remote control of house model, lighting, door and lamp band by kc868-h8 PC software
KC868-H8 smart home gateway input manual switch
kc868-h32 relays control by ethernet network http url string in browser.
Smart home demo box, including lighting control (Zigbee light panel, Zigbee dimming panel, radio frequency light panel), household appliances control (infrared control equipment such as TV, air conditioning, DVD player),…
8 channel power box control by phone APP and computer software or voice control by Google home or Amazon alexa speaker.
Praesent euismod volutpat rhoncus. Suspendisse rutrum tortor justo, eu sollicitudin nisl pretium et. In a elit ligula.
Dofelis vel mi finibus pretium nec pretium tellus. Donec a purus vehicula, fringilla ligula ac, posuere nisi. Cras nisl lacus, volutpat a odio posuere, iaculis sollicitudin purus.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nulla sit amet lectus erat. Nullam ex sapien, bibendum et blandit id, mollis id ligula. Sed maximus cursus sem eget viverra.
Suspendisse rutrum tortor justo, eu sollicitudin nisl pretium et. In a elit ligula. Cras nisl lacus, volutpat!
Phasellus a justo eu sem pulvinar tincidunt eu ut arcu. Quisque id accumsan elit. Integer finibus lobortis fringilla. Aenean tincidunt id velit non volutpat. Praesent quis maximus nisi.
Morbi mi neque, consectetur ut convallis at, semper sit amet elit. Curabitur gravida porta ante et sagittis. Praesent eget nunc elementum Praesent eget nunc elementum lacus pretium malesuada. Nulla imperdiet…
Curabitur ut felis vel mi finibus pretium nec pretium tellus. Donec a purus vehicula, fringilla ligula ac, posuere nisi. Cras nisl lacus, volutpat a odio posuere, iaculis sollicitudin purus. Praesent…
Aenean eget feugiat leo. Donec pretium bibendum elit, eget ullamcorper urna malesuada nec. Phasellus a justo eu sem pulvinar tincidunt eu ut arcu. Quisque id accumsan elit. Integer finibus lobortis…
Smart home demonstration model, The whole villa through manual and mobile phone APP remote control of various types of devices. Common function display of smart home.
This video demonstrates the example of the kc868-h32 smart home gateway controlling the lamp by mobile phone APP.
This video demonstrates the example of the kc868-h32 smart home gateway controlling the lamp by PC.
1.without connecting to smart house controller, dual and triple controlling function available. 2.Circuit of the hardware is optimized, wireless controlling is enlarged, suitable using for normal apartments and villas. 3.Newest…
8051 MCU development board kit learning board 51 MCU tool dev board
Economic 51 MCU development board 8051 study kit on board ISP dev board
51 MCU GPS development board kit with TFT
EM310 MG323 GPRS Serial development board
GPS Development Board gs89 module with TTL level and RS232 level SRIF Star III
Bluetooth GPS GPRS MCU development board kit location tracking google map
GPS Development Board gs92 module with TTL level and RS232 level SRIF Star III
EM310 MG323 MC323 GSM GPRS CDMA development board
K150 USB PIC Programmer for Microchip with ICSP
The advantages and characteristics of our latest research and development of FM module: 1, the FM transmitter module onboard microphone micro high sensitivity microphone, the materials we use mobile phone…
July 3, 2014 ~9, at the invitation of Thailand AMR group, I went to Bangkok with technical personnel, and coordinated the promotion of KinCony smart home in the “MY QZONE”…
Features Mode: Remote control and Panel buttons. Not only can remote control and also can control with panel button apply to traditional habits. Smart RF socket support network range extend…
kc868-g Smart Home Automation Universal Intelligent Remote Controller. WiFi+RF315MHz+RF433MHz
KinCony Smart home system Automation APP Video demo
how to use kc868 Smart home system Automation gateway
Smart home system Automation gateway oem/odm logo
KinCony offers the ultimate home automation solution by making the products and systems you already have and use everyday, work together.
KinCony offers the home automation solution by making the products and systems you already have and use everyday, work together.
Our smart home controlling products can be controlled by Ethernet and wireless. These stable, functional complete and fast update products are widely used in industrial controlling and smart home area.
Features Adopted high quality crystal tempered glass panel and fireproof ABS plastic, preventing excessive heat result in fire, reduce the security risk. Mode: Remote control and Panel buttons. Not only…
Descriptions PM2.5 has become one of the most significant health parameter in many countries. With the increasingly serious smog over the city, people pay more and more attention to air…
Output Load:each 250V/5A Communication mode:Ethernet/RS232 Input port qty:6 ports Output port qty:32 ports
KC868-H8 is a smart home automation that remote control relay by network. It can used by mobile phone APP or PC computer or PAD.
KC868-F Smart Home Controller : 1.It can send 315MHz 1527 code wireless signal. 2.It can send ZigBee 2.4G protocol signal for KinCony ZigBee product. Such as ZigBee light, ZigBee Dimmer,…
Smart Lighting Control System Implementation Case This Case will show us how to control the lighting with the device KC868-H8, and what kind of controlling ways. Firstly, let us…
